SUPPORT OUR SPONSOR
February 2026
Old 10-26-2001, 09:17 PM
Question Which Flywheel
Anyone ever hear of a 153 tooth steel flywheel for a 428? What is the correct or most widely used 'wheel with a 428? Thanks for any info, Hurley
Old 10-26-2001, 10:09 PM
427sharpe's Avatar
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
Post
Most common is the 184 tooth w/ 15.503" OD ring gear. 427's used zero balance, most 428's used 28oz counterbalanced.
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
Old 10-26-2001, 10:46 PM
Question Flywheel
Torque-e-modo,
Do you happen to know what a 153 tooth would have been used on? I had never heard of one.
Thanks,
Hurley
Old 10-27-2001, 08:42 AM
Default flywheel
My flywheel is a McLeod unit with the correct 28oz unbalance for a 428. A lot of the original flywheels are getting pretty old and it is probably safer to go with a new one. David Kee sells these flywheels as well as the mating clutch pieces. I am running a McLeod dual friction setup which my builder claims is not as hard on flywheel surfaces as the centerforce setup. Pedal feel is reasonable with 3/4" master and McLeod hyd. throw-out brg.
If you are running a 427 you might want to ask David about flywheel weight as the faster revving 427 might respond well to a lighter flywheel. I can get you my part number if you need it.
Gary
Old 10-28-2001, 08:00 AM
427sharpe's Avatar
Arrow
hford: Success! I finally found a 153 tooth listing! The medium duty trucks used a 153 tooth, 13.735" OD flywheel for a few years. Used mostly on the 330/352 it seems. Not a good choice for a 427/428, as you would have to use the old 352 bellhousing, starter etc..My suggestion--a new scattershield with a new steel flywheel (McLeod/Lakewood sell both). Safety first!!
HTML code is On
