February 2026
Old 10-28-2001, 08:10 AM
renaissance man's Avatar
Cobra Make, Engine: SMC Motorcars 289
Send a message via Yahoo to renaissance man
Default Expansion Tank?
I know the expansion tank is at the highest point on the engine. Question is; is the overflow run to the radiator? If so, is there a special cap that I need to allow for the flow back into the radiator since most caps are sealed?
What about running the take to a water jacket inlet on the block itself since this is higher than any place on the radiator?
Co-founder of the Texas Cobra Club.
Dave "Ren Man"
Old 10-28-2001, 01:21 PM
Okiesnake's Avatar
Cobra Make, Engine: Unique 427SC, 351W
Are you talking about the expansion tanks used on the 289 or the 427?
I've include a pic of a 289 expansion tank set up.
Old 10-28-2001, 01:24 PM
Okiesnake's Avatar
Another expansion tank from a Tiger
Old 10-28-2001, 01:25 PM
Okiesnake's Avatar
Here is a pic of the expansion tank I set up on my Cobra with a 351W
Old 10-28-2001, 01:30 PM
Okiesnake's Avatar
Sorry. That last pic was not the pic of my car.
Hopefully this new post will show my set up.
Old 10-28-2001, 01:45 PM
Okiesnake's Avatar
I had a local muffler shop bend some 1 1/2" pipe to the shape I formed from a bent coat hanger. I wielded some 90 degree elbos to the pipe and threaded some brass hose fittings to them. I had them ceramic coated. The Canton Expansion Tank was purchased through Unique (approx. $80). As you may be able to see, the rear fitting goes to the upper port on the Canton expansion tank and the forward fitting goes to the lower Canton Expansion tank. The overflow hose is just that, an overflow hose open to the environment. This is how the orginals were set up.
I did some research on how the originals were set up. When I first filled the collant system, I first filled up the engine by removing the temp sensor. I then filled up the rest of the collant system straight through the Canton Tank. It did not take long.
I have over 1,000 miles on my car and have never had to add additional collant.
I also shaped my lower radiator hose form 1 3/4" pipe that I also ceramic coated.
Old 10-28-2001, 01:49 PM
Okiesnake's Avatar
lower hose pic.
I did use rubber radiator hoses to connect the upper and lower hoses to the radaitor and engine for vibration isolation.
Old 10-28-2001, 01:50 PM
Okiesnake's Avatar
sorry, fogot the pic
Old 10-28-2001, 05:12 PM
Cobra Make, Engine: Unique FIA; 351W
Default Okie
VERY nice looking setup. You've given me more under-the-hood stuff to obsess about over the winter.
Old 10-28-2001, 05:51 PM
Okiesnake's Avatar
One last pic
Old 10-31-2001, 08:59 PM
mickmate's Avatar
The expansion tank is plumbed into the cooling system below both seals of the cap. Between the seals it is plumbed to a drain pipe or a catch tank for a dry race track. I got a tank off an old Thunderbird for $8 and turned it around on the plumbing to make it a left hand exit a la Cobra. Blasted and painted it. Mumma thought it was a new one.
Cheers Nick
mickmate
http://www.actoncustom.com/
