SUPPORT OUR SPONSOR
Old 11-16-2001, 05:46 PM
Unhappy 9 inch placement woes
has anyone had a problem centering the 9'' narrowed rear end on their car,I set the pinion center line in line with the c6 trans, both at 11 1/2 off the inside frame rails [23] . now the drivers side axle flange is 1 '' over to that side. if I center the axle based on side to side consideration, the pinion centerline shifts to the passenger side and the driveshaft would be running at an angle or "offset". the axle came with the car[kit] has anyone any experience with this kind of problem before? I can't imagine, but it's possible it was reworked improperly.
carlo
HTML code is On
