| S |
| 1 |
5 |
| 8 |
12 |
| 15 |
19 |
| 22 |
26 |
| 29 |
30 |
31 |
1Likes
Post By FWB
04-13-2014, 06:35 AM
NJ
Cobra Make, Engine: Contemporary Cobra
Electric Power Steering
Has anyone installed this on their cobra? If you did could you share how and the parts.... I read that the pump from the MR2 works well but nit sure what else is needed.
Jon
Advertising
04-13-2014, 06:42 AM
PA
Cobra Make, Engine: Myself/Body from CSX-2575 & hand built Birdcage
Why do you need PS in a Cobra?
6S1941
Allied 289 Slab Side
73 2.3 turbo pinto
04-13-2014, 07:32 AM
NJ
Power Steering
I'm having a problem with my shoulder and neck, it's becoming more uncomfortable during and after driving and I don't want to stop driving the cobra.
Just looking into the idea..,
Jon
04-13-2014, 09:12 AM
Ill
check out the units on the new Camaro
04-13-2014, 09:32 AM
CO
I have not heard of anyone using the MR2 or S2000 components. As I understand it, they are integral to the steering column, and difficult to integrate. They are also both speed sensitive, so it needs some input to make it work right. Not insurmountable problems, but I have not seen anyone do it yet.
Flaming River makes a kit that is similar to those two, but it's very expensive.
There is another electric P/S kit that uses an electric motor to run the P/S pump. I can see that would have some advantages.
I have the same problem you do. Some military injuries make it difficult to muscle the car around the track on the week ends. 200+ high speed corners during the course of the week end can really wear you out.
After some research, I spent big bux on race ready components: KRC pump, braided lines, AGR rack, etc. Expensive, but it works well and should be reliable.
For a street car, I'd use stock Mustang components. Simple, inexpensive, easy to come by, and reliable.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
tx
Also try Fast Freddies.
He has a package that has everything you need. Electric pump, switches, hoses, reservoir. I'm not sure he has the ps racks, but those are easily obtained.
04-13-2014, 09:44 AM
Ca
We have them on the Chevy Cruze since its intro.
Rick
04-13-2014, 01:43 PM
NJ
Steering
Thnx for the info, I looked at Fastfredies and inquired if it would work on a mustang ii rack...not sure why it wouldn't.
Jon
04-13-2014, 03:10 PM
PA
77 mustang ps rack
75 pinto pump
69 full size ford ps bracket
fe dual wp pulley
need to make up hoses
using the pinto pump eliminates the need to worry about pressure from a saginaw pump
just got done doing a 80' kellison works perfect
Fred B
04-13-2014, 05:53 PM
qld
Cobra Make, Engine: Kirkham 427SC 482 Cammer
check out KYB they do a neat little electric power steering unit that will fit perfect behind the dash and connect to your existing steering shafts etc
I have used these in racing applications and they cop a fair bit of treatment.
04-14-2014, 05:16 AM
UK
Cobra Make, Engine: Kirkham #523, 427 S/O
Have a look at these. I've heard and read great things about them:
Home
Paul
04-14-2014, 06:02 AM
NY
Cobra Make, Engine: 1966 Griffith 400
Electric Power Assist
Well, sort of... I did not use this brand, but installed a unit from an Opel Corsa, used. It came off of Ebayuk.com, was all clean and checked out, and additionally came with a potentiometer to vary the amount of assist.
The Corsa unit is very compact. It works great. I have a '66 TVR Griffith with very large front rubber, and absent the electric assist, it's extremely tough.
The gentleman I got it from was from Ireland, and lists frequently. If you look for him and can't locate, I can retrieve his user ID.
I really think its great. The Corsa unit fit right up under the dash when no other would.
Roger
04-14-2014, 08:21 AM
CT
We've installed this kit into one of our 427s. It's relatively cheap, but it lacks any speed control, so we also installed a switch to cut off the boost. Otherwise, the steering is really too dead at speed. The owner was very pleased at how it worked. With a little work, you could probably integrate a speed sensor to automatically disable the boost over 20 mph.
As has been said, there are more sophisticated (speed-controlled) boosters, but the price is way up there. "Adapting" a production electric booster is not easy, since they typically get several inputs from the car's main computer. That means, in a conversion, you have to "fake" some input through a separate controller.
HTML code is On
