Old 09-11-2015, 11:30 AM
EarlsflyinCobra's Avatar
Ouch Ouch Hot Sand
Send a message via AIM to EarlsflyinCobra
Default How much paint do I need for my Stripes??
As the title says, How much paint do I need for my Stripes?? Should I buy a pint, a quart, or what? I'm told a gallon of paint will do the car itself so what about the stripes??
Thanks, Earl
Old 09-11-2015, 07:50 PM
Cobra Make, Engine: Shell Valley, 351W
I bought a quart when we did my car and I have about 2/3 of it left. we used almost 1/2 gallon of color and about 3/4 gallon of clear for the whole job.
Old 09-15-2015, 08:48 PM
Cobra Make, Engine: Pacific Roadster, 427 stroker, TKO 500
It all depends. What color are the stripes? What color is below the stripe? What brand of paint are you using? What is the reduction ratio i.e. 2-1, 3-1, 4-1? If you are going with the traditional white stripe and you are going to paint over black then you will need a little more material. If you are using a quality brand base coat such as DuPont, PPG, BASF Sikkens, Glasurit etc you will have excellent coverage. A ratio of 2-1 means 2 parts color and 1 part reducer as an example. Quality brands have much more pigment and cover quickly. Lesser brands will require more material as they do not have the pigment. So if you are going with a quality brand base coat a pint will be more than enough. Anything else I would think about a quart of material.
Old 09-16-2015, 04:47 AM
mrmustang's Avatar
Gold Star Contributor
Originally Posted by autobody prof. View Post
It all depends. What color are the stripes? What color is below the stripe? What brand of paint are you using? What is the reduction ratio i.e. 2-1, 3-1, 4-1? If you are going with the traditional white stripe and you are going to paint over black then you will need a little more material. If you are using a quality brand base coat such as DuPont, Sherwin Williams, PPG, BASF Sikkens, Glasurit etc you will have excellent coverage. A ratio of 2-1 means 2 parts color and 1 part reducer as an example. Quality brands have much more pigment and cover quickly. Lesser brands will require more material as they do not have the pigment. So if you are going with a quality brand base coat a pint will be more than enough. Anything else I would think about a quart of material.
X2
Old 07-03-2018, 01:11 PM
Registered User
Cobra Make, Engine: Ford
Nobody likes to apply decals? My Mustang came with decals on the hood, roof and trunk from the factory. My only concern is the longevity. Painted ones would seem to last a long time if you have a good clear coat over them and get the car waxed periodically.
