Like Tree8Likes
  • 3 Post By twobjshelbys
  • 3 Post By xb-60
  • 2 Post By mikeinatlanta
Old 05-22-2018, 08:00 PM
Registered User
Default Finally got a cobra help please
So I bought this 67 shell valley cobra from a military man the day before he left for Alaska. All I know is that it was built in 2000 with a SMBC 327 with a auto trans. The brakes are horrible which im working on. I don't know alot about these cars but am capable enough to do all the repairs. What i need help in is the rear end. I want to put an independent rear suspension on it. Right now its a solid rear axle with QA1 coil overs on it. What should I change it to. Eventually I want to change the engine and trans. Looking for an upgrade that will work with what I have and in the future. I'm just triing for a solid driver no race or track.
Old 05-23-2018, 01:44 PM
lnfletcher's Avatar
Curious, why go to the expense of the IRS?
Old 05-23-2018, 03:14 PM
Where are you located?
Old 05-23-2018, 04:59 PM
Grubby's Avatar
Cobra Make, Engine: ERA 838
Jag IRS is a pretty easy swap. It is self contained in a cage. Look at the ERA web site for some pictures.
Old 05-23-2018, 08:02 PM
vntgspd's Avatar
Cobra Make, Engine: ERA #347
Contact Dana at Shell Valley. They are nice folks to deal with. I'm pretty sure they offer an IRS option now and I wouldn't be surprised if they share the necessary frame modification details with you as well as the hardware they use. I think it may be T-bird based.
A Jag IRS is a nice package as well...
Old 05-23-2018, 08:19 PM
twobjshelbys's Avatar
But why bother? If you're just going to drive it on the street it'll be a big chunk of change and it won't make your car more valuable. My Mustangs with straight axle were awesome and I think did a better job of getting power to the ground.
Buzz, Dwight and Blue66 like this.
CSX4005LA
Old 05-24-2018, 02:31 AM
xb-60's Avatar
Originally Posted by twobjshelbys View Post
But why bother?....
I agree with Tony. Why bother? It will cost you a lot to change the rear end completely, and same comment for the engine and transmission.
Why not enjoy it, spend only what you have to on it, and if you then after a period of time decide that Cobra replicas are really what you want, sell it and buy something with the IRS and the engine and trans. that you want.
Glen
Old 05-24-2018, 03:54 AM
Best way to do the swap is spend some time making the car look as presentable as possible, sell it, buy car with IRS. Unless you paid too much it won't cost much and you'll still be driving a cobra.
Buzz and twobjshelbys like this.
Old 05-24-2018, 07:08 AM
Another aspect of major mechanical changeovers is that the car is down for the count. That could a big chunk of the season if you do it yourself. Why not drive it for the rest of the summer and then undertake whatever changes you finally decide you still want during the winter downtime? You may find that the suspension is just fine for what you want to do with it.
CSX4005LA
Old 05-24-2018, 07:19 AM
PNJSNAK's Avatar
Cobra Make, Engine: A&C 427S/C, 351W, T5
Agree with why bother if you don't plan to track it.
If the rear end does not have adjustability, I would change out the solid members to ones that can be adjusted. That is easy to do.
The 4 link usually comes with solid bars. You can get adjustable bars from Shell Valley.
Pictures?
OhioCobraClub.com
Old 05-24-2018, 11:30 AM
vntgspd's Avatar
Glen
Yep! This is exactly the path that I took and couldn't be happier with the process.
Old 05-24-2018, 12:55 PM
cycleguy55's Avatar
The best way to swap in an IRS is to change the VIN at the same time. IOW, sell what you've got and buy a car with an IRS.
Edit: But you're on the right track with the brakes - at least make it safe to drive before you sell it.
Brian
Old 05-25-2018, 10:14 AM
Registered User
Thanks for all the advice. My current rear end feels loose when i'm driving. I thought the IDRS would help with that and increase value. I'm going to just redo all the bushings in my current rear end to help tighten it up. Thanks again.
Old 05-25-2018, 10:20 AM
Registered User
Sorry REDMT i'm just outside St. Louis.
Old 06-29-2018, 10:38 AM
Glen
Agreed
Old 06-29-2018, 11:19 AM
fastd's Avatar
I'm no expert but...
figure out what is making your rear end loose...bad design, improper installation or otherwise.
Jury is out as to whether you'll pick up performance by switching to an IRS (sacrilege I know). Ride height adjustability clearly better with the IRS, other than that, it seems to depend about quality of parts and installation.
Figure it costs at a minimum, what $5k for an IRS? versus what is the cost of fixing up what you have...
Might help with value if you were to sell your car...i think it depends on what the total package looks like to see if your car screams for an IRS or whether buyers just wouldn't care.
Old 06-29-2018, 11:21 AM
fastd's Avatar
you already have qa1 coilovers on it...that makes me more strongly think that you should leave it alone and just tighten it up...ford 9"? definitely leave it alone.
