February 2026
6Likes
Post By patrickt
Post By patrickt
Post By ERA 626
3
Post By bkozlow
01-12-2021, 11:54 AM
heater shut off
I am curious, Do most of you plumb in a shut off valve for your heater? or simply let the hot water run through it 24/7/365?
01-12-2021, 12:27 PM
There was a shut off valve on the engine on original 289 Cobras.
Plumb it in. It only takes two minutes and it makes a difference during the summer (and winter).
01-12-2021, 03:30 PM
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
I have one like Patrick's but I've never turned it off even once. I need to try that on the next hot drive to see if I notice a difference.
01-12-2021, 04:38 PM
AL
mine was a Mustang unit, vacuum controlled so I could turn it off or on from the driver seat.
01-12-2021, 04:51 PM
Cobra Make, Engine: SPF832, 466cid
Dash pull cable to a heater hose valve.
01-12-2021, 05:10 PM
Uhhh, personally I think it's kind of cool that when your passenger complains that they are too hot you have to pull off the road, get out, lift the hood, and turn a valve handle only to have them say they are too cold fifteen minutes later.
01-12-2021, 08:07 PM
If your Continuation was supplied with a heater there should be a cable controlled heater valve just above the passengers foot box.
01-12-2021, 08:14 PM
No it was not... I installed my own heater.
On my ERA car I had one like in the photo above, i turned it off during the summer months. I was just wondering what other guys are doing...
01-21-2021, 05:31 AM
Cobra Make, Engine: built the molds and body composite construction
Many people don't have a heater so this is not an issue. Many ask about making their oil cooler functional, should they or not, well in FL reducing heat is the main concern. I really don't need an oil cooler on the street, so I turn my oil cooler in to another radiator by running in the warm weather the heater lines to it. When I need heat, I reconnect them to the heater. On a Daytona which has a large oil cooler you pick up an additional 10-15% cooling capacity by running your heater water thru the cooler. If I saw temperatures in the oil that warranted it, I would reconnect the oil cooler as an oil cooler but I don't. Just a thought.
Bill K
03-22-2021, 07:10 PM
MD
[url=http://www.clubcobra.com/photopost/showphoto.php/photo/68405]  [/ur
Yes, I run a simple mechanical cable actuated water valve from the 1970’s I picked up from NAPA and put it near heater core out of site. The mechanical choke cable I used is also hidden low in the pass foot well to control the valve.
