SUPPORT OUR SPONSOR
Like Tree9Likes
Old 11-25-2022, 08:39 AM
kevins2's Avatar
Cobra Make, Engine: ERA #795 427 S/C completed Jan. '14 - '68 FE 427 side oiler
Default Any idea what this is?
I changed the oil and this was stuck to the magnetic drain plug. I attached two photos to show it has a slight concave shape. I strained the oil and found no other metal, the engine is a side-oiler and runs good - no symptoms. Any clues?
Thanks,
Kevin
"Anyone who drives faster than you is a maniac and anyone who drives slower than you is an idiot" - George Carlin
Old 11-25-2022, 10:44 AM
No idea, but you know it sticks to a magnet. It wouldn't hurt to pop the valve covers off and have a look-see just in case.
Old 11-25-2022, 11:54 AM
kevins2's Avatar
Thanks, I’ll do that.
Old 11-25-2022, 04:42 PM
Piece of a valve spring? Can't imagine it a piece of a valve seat without having some poor performance. The radius throws me.
Old 11-25-2022, 04:54 PM
PaulProe's Avatar
Cobra Make, Engine: Hurricane - FE
Kevin
Do some reverse engineering on the radius to determine what the diameter was, approximately. Will help you to narrow the search.
Depending on size, could be a part of a snap ring from a lifter, part of a ring, part of a piston pin keeper, maybe a chip off the distributor gear
Just some ideas
Paul
www.65shlb.com
www.prdcrrct.com
Old 11-25-2022, 07:43 PM
kevins2's Avatar
Good idea Paul. I’ve got a bin full of washers of various sizes that will enable me to approximate the diameter. I’ll do that tomorrow.
Old 11-26-2022, 07:00 AM
kevins2's Avatar
By comparing the curvature of this piece of metal to various size washers, the diameter is 1".
Old 11-28-2022, 12:49 PM
1985 CCX's Avatar
Its a Kunooder
Old 11-28-2022, 03:59 PM
Tom Wells's Avatar
Kevin,
Dumb question #xxx37: could it be part of the oil pan?
Tom
Old 11-28-2022, 06:15 PM
kevins2's Avatar
Tom,
Not a dumb question. I have no idea what it is. Will start inspecting everything I can as soon as I can get to it.
Thanks,
Kevin
Old 11-28-2022, 07:17 PM
Cobra Make, Engine: Unique 445 FE stroker
Kevin,
Unrelated to conversation, but really like your paint choice, what red is it? I have a Unique being built and going to paint soon. Trying to decide on color.
Old 11-29-2022, 06:19 AM
kevins2's Avatar
Hi Razor,
It is a GM color used on many different vehicles from Corvettes to trucks until around 2012 or 2013. After that, GM replaced it with a slightly different red called Crystal Red Tint. It was available in both two and three stage configurations - I went with two stage.
Red Jewel, GM code WA301N, PPG 908589. The stripes are Evoke Gray, GM code WA354N, PPG 918801
Buzz, RAZOR and Sargie like this.
Old 11-29-2022, 06:52 AM
Chicagowil's Avatar
The way it is slightly bent, I suspect it is part of a locking washer. The type where you tighten the nut/bolt and then hammer the edge of the washer up to lock it in place. Sometimes the hammering can cause a fracture crack where it bends up against the fastener.
Not familiar with the assembly of the side oiler. Take a look in the manual ans see if you can locate such use internally. I would not be too concerned if that is where it came from.
If you are seriously concerned, you can take a sample of your oil to an aircraft oil analyzer company, and they can see if there is an unexpected amount of metal in the oil.
Old 11-29-2022, 11:38 AM
Danr55's Avatar
Looks like a piece of the valley pan.
Dan in Arizona
CCX3209
Old 11-29-2022, 02:05 PM
Kevin,
Thanks for the info, you have an awesome looking car.
Rex
kevins2 likes this.
Old 11-29-2022, 03:04 PM
kevins2's Avatar
Smile
I’m still hoping one of the resident engine builders will recognize it.
Old 11-30-2022, 06:29 AM
Buzz's Avatar
The only thing I can visualize is maybe a chunk of a broken section of dipstick tubing? A piece of the pressed/rolled section at the upper left of this image?
Tropical Buzz
Old 11-30-2022, 06:31 AM
Does your engine have a valley pan?
https://www.2040-parts.com/ford-352-...orino-i259396/
Old 11-30-2022, 07:18 AM
t walgamuth's Avatar
looks like a part of a washer that goes around the valve spring.
Old 11-30-2022, 08:22 AM
kevins2's Avatar
No, it does not.
HTML code is On
