SUPPORT OUR SPONSOR
Like Tree1Likes
  • 1 Post By toadster
Old 12-01-2004, 06:28 AM
I-zoom's Avatar
Question hOOD Rivits?
Here comes a newby question! Some 427 Cobra's have rivits showing through the hood in the front,even some of the nicest ones?? I used to work for a guy building cobras and never seen this before?? Most of the cars coming from third world counties have these rivits showing...how come??
Thanks in advance,Newby!
Wanna buy a boat??
Wanna trade your cobra??
Old 12-01-2004, 07:37 AM
The rivets are a relic from the competition cars. Beginning with the Le Mans model cars manufactured for competition by AC in '64 the aluminum adjacent to the body support tube at the front of the hood was rivited to the tube. The competition cars showed evidence of strain in this area as air buffeting from under the car pushed against the closed hood. The aluminum was pulling away from the supporting tube. The rivets reinforce the join.
Several of todays replics repeat the rivet pattern, including cars that are manufactured in fiberglass and have no need for reinforcement. The 'rivits' on my Superformance are purely cosmetic and a buyer has the option to delete them from the completed body.
A beautiful car, precisely assembled. Unfortunately I don't fit. Sold it after four hundred miles. Well, at least now I know a Cobra is not a car I can own.
avanti-176's Avatar
Cobra Make, Engine: Contemporary classics 3041,sbc 350(have no fear ford guys for there is a FE 428 in the garage waiting to be rebuilt & installed) but for now she is a driver while other projects take precidence.
Because that is the way the ORIGINAL aluminum bodied Cobras came.
Now just ask about the spacing.....I dare ya'.
Dan
THOUGHT FOR THE DAY: There is more money being spent on breast implants and Viagra than on Alzheimer's research. This means that by 2030, there should be a large elderly population with perky boobs and huge erections and absolutely no recollection of what to do with them.
Old 12-01-2004, 07:40 AM
avanti-176's Avatar
oops!
Steve beat me to it! with a much more detailed answer also.
Dan
Old 12-01-2004, 07:42 AM
As the story goes, early Cobra racers experienced aspiration problems. Someone went to a local speed shop and bought an aftermarket fiberglass hood scoop to help force air through the engine. It was fastened using pop rivets. Problem solved. Replica manufacturers mold the scoop into the hood in production. More authentic to have pop rivets and there is a proper spacing although I can't remember the exact numbers.
The same was true for the rivets around the front of the hood. During racing, the high airflow across the hood skin caused the skin and 1 inch tube frame to separate. Pop rivets solved this problem too. To be more authentic, some owners pop rivet their hoods and scoop to make the car look like an original CSX. The pinnacle of fake snakes.
Old 12-01-2004, 07:49 AM
Looks like a bunch of us jumped on this one. I saved a copy of the hood rivet spacing somewhere, but can't find it. Probably put it in that 'safe, easy to remember place'! Since they were done after production by individual owners, I really don't think there was a specific spacing pattern. Find some good detail pictures of original cars and make your own pattern.
Old 12-01-2004, 11:09 AM
Roscoe's Avatar
I did not do the scoop but on the hood I used 6/32 stainless button head machine screws. I drilled and tapped the hood and gently screwed them in with a little loctite. I think they are better than rivits as they do not crush the glass.
Roscoe
Old 01-31-2005, 08:10 PM
dlampe's Avatar
Default the hood rivot thread
I thought someone was looking for this thread so I am bumping it to the top. My search function was not working.
Old 01-31-2005, 09:40 PM
pgermond's Avatar
16 per ERA manual
Phil
http://www.uniquecobra.com/
Old 02-01-2005, 04:43 AM
Send a message via AIM to mj_duell
I used the same diagram as Roscoe for my rivets. I took stainless rivets polished them and then removed the shanks. I drilled 1/8 inch holes and used black RTV as an adhesive on the rivets. This worked well becuase it was easy clean up and they can be removed if needed. I decided to do the scoop even though it is molded into the hood.
--Mike
Old 02-25-2023, 11:27 AM
toadster's Avatar
Cobra Make, Engine: FFR #9772
Send a message via ICQ to toadster
Maxjeep likes this.
Build Details
25th Anniversary Mark IV | #20 of 25 | Build #9772
25th Anniversary FFR Registry
HTML code is On
