SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 02-22-2002, 01:05 PM
JT JT is offline
Cobra Make, Engine: Antique & Collectible 302
Question Header advice, please....
Here's what I got: 1-3/4" steel primaries, into slip-fit steel adapters, then inserting into 2" stainless collectors and sidepipes.
Q: how to fit up everything? I believe I'll weld the adapters onto the primaries, but then what? I don't think welding mild steel to stainless is a good idea.
Options: 1. Using header wrap and clamps like Roscoe did.
2. (Here's where I'm open to suggestions).....
Thanks again you guys.
Greyhound adopter.
Old 02-27-2002, 08:59 AM
The best way to hold these together is to use a welded on tab on two opposing tubes and two opposing collector tubes with a 1/4 inch bolt fastening them together. Use a exhaust sealer on the inside of the sidepipes to sel them up. Use sparingly as not much is needed. A tig welder will do a much nicer looking job. P.S. will hold in too much heat and burn the carbon out of the metal cand cause the part to fail.
Pat Moore
Old 02-27-2002, 06:19 PM
Think twice about header wrap. I've seen headers rust out pretty quick because of trapped condensation when the headers cool. Good Luck.....Jim
Never throw sand on a carburetor fire
HTML code is On
