SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Like Tree1Likes
  • 1 Post By Cobra20646
Old 01-17-2002, 05:56 AM
renaissance man's Avatar
Cobra Make, Engine: SMC Motorcars 289
Send a message via Yahoo to renaissance man
Default Checking/Adding 90W to a Toploader?
Anyone have any idea how to add fluid without dropping the tranny? Better yet, how do you check the fluid level in your Toploader? The fill plug is on the upper right side of the Toploader?????
Co-founder of the Texas Cobra Club.
Dave "Ren Man"
Old 01-17-2002, 06:09 AM
Shade Tree Mechanic
Cobra Make, Engine: - Unique - 302 - 4 spd. -
Dave,
To check the level, remove the fill plug and stick your finger in the hole. You should be able to "feel" the fluid level even with the botton of the hole..... providing the car is level.
To top it off, I remove the shifter boot and stick a plastic hose through the opening in the tunnel and insert it into the fill hole. I then add a little at a time via a funnel hooked to the plastic line. Just keep adding a dab at a time until the fluid runs out of the hole. Put the plug in and clean up what spills on the floor and your done.
- Jim -
vpmerlyn likes this.
- Jim Harding -
- Capital Area Cobra Club -
- Just another day in Cobra Paradise -
Old 02-24-2002, 05:48 PM
I added an access plate to the transmission tunnel. I found a perfect cover in the electrical supply department of Lowes or Home Depot. It was round with a gasket and two screw holes.
Old 02-24-2002, 06:54 PM
Clois Harlan's Avatar
Default Trans Fluid for Toploader
I used a tool that most people use to add fluid to their battery , a syrenge type thingy with a red rubber squeeze ball on top of a long plastic tube. Hell I don't know what it is called, but it works.
"Let's roll"
"Be part of Something Good
Old 02-24-2002, 08:00 PM
CSX 4027's Avatar
Cobra Make, Engine: Sold 3047 & 3002 in 2012
Default Toploader
I use a flexible and add to the fill plug hole. Also it is a good idea to tap a drain plug hole on the bottom to change fluid annually..
Steve Sunshine
www.competitionlife.com
"Hurry Up And Live"
Old 02-24-2002, 10:36 PM
You add oil to your toploader like any manual transmission or rear end, you simply pump it.
Old 02-25-2002, 08:22 PM
427sharpe's Avatar
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
What drama! An auto parts store will sell a cheap pump just for gear oil--you can use it to draw the fluid out as well, and change it if you want to. To fill, fill until it starts to drip from the fill hole and you're done. Next time you have the trans out if you look, most toploaders have a boss (unmachined) on the bottom for a drainplug. You can drill and tap a hole if you want a drain, but after doing so be sure to clean the case very well before re-assembly. The pumps are nice because they usually come with about 1-2 feet of hose, which means that the gear oil container doesn't have to be under or in the car, which will lessen the chances of a stinking mess.
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
HTML code is On
