SUPPORT OUR SPONSOR
Old 02-26-2002, 04:07 PM
Default The turkeypan or the 14" air cleaner choice
Hi
This is like the last thing I have left/avoided buying....I have searched and read countless posts on either.
I have a couple questions
Will the turkey pan Enzo sells contain a Holley 850 ? It is the mech sec. manual choke (model 4150 I think)
I am 428 with Edelbrock RPM intake
MSD Billet distributor
I am worried about th
e fit into the pan.
I am also kicking around K&N style 14" drop base .I am not sure about what element as I don't know exactly how much clearance I have to the hood opening. The hood scoop is 11" wide and I am screwed if the 14" top starts to get up into the hood.
I think a drop base with a 3" filter will fit as I can see into the hood opening from the front and see a decent clearance above the black plastic holley cover/cap easily.
So this boils down to the turkey pan again..original and cool for shows etc...no worries about clearances possibly. Performance at a disadvantage as it is said to be very restrictive.
Money?? In Canada the K&N is $120 or
$75 US The pan is $175, the S&H with K&N element 65+55 $120..so $295 US.
475 CDN or 120 CDN..
If my cars resale was hanging on this very part I could see buying one then.
But it seems so darn steep and for what??
I don't know....if it boiled down to performance/value, I would go 14", for originality and hood opening pride...Turkey pan. But I find it hard to swallow losing 30 or 40 horse on breathing.
What are your thoughts on this and how is the best way to calculate filter clearances before I buy an element...ie 3 or 4"?
Thanks
Tim
Old 02-27-2002, 04:48 PM
Well what the hell...needed something now and so I jumped into a 14" drop base with K&N 3 inch element as well as the x-treme top in polished aluminum finish..
Don't think that should have any problem breathing and according to zderf's formula theres ample of breathing area not even counting the lid.
Turkey pan can come later.
Tim
Old 02-28-2002, 12:02 PM
decisions....I cancelled the 14" went to 9 inch with both the chrome top and the x-treme top..then ordered up a turkey pan.
Couldn't sleep until I did this...LOL
Tim
Old 03-02-2002, 08:45 AM
Default air cleaner
LOL--- i know what you mean, i spent 2weeks thinking of changing from my chrome 10 inch to something else wanted the large oval cobra air cleaner but no clearance, now i will go with a nice aluminum 12inch oval and maybe the turkey pan, i will not do this i cannot get good flow, i want HP over looks if possible or i will try and get both. you could cheat and add NOS then you have no worries about HP loss.
Mkcobra
Well officer.. It was like this.
Old 03-02-2002, 06:50 PM
Default Does anyone know if a Holley 850 will fit the turkey pan?
MKCobra I hear ya...LOL
Just curious to know if a Holly 850 mechanical sec, mech choke will fit in the Turkey pan Enzo sells??
I imagine enlarging or elongating some holes ...but is anyone running the same??
Tim
Old 03-02-2002, 08:41 PM
Default turkey pan
well , i was in austin and did see alot of the turkey pans they are large and the 850 fit well, some even had the 12 inch oval i am running sitting on top, look in the tech formum under dist 351W there is a pic of a nice setup.
Old 03-02-2002, 09:44 PM
Thanks MKCobra
Thats re-assuriing and good to know.
I will have a look ion the tech forum
Tim
Old 03-04-2002, 09:03 AM
Default Another consideration on fit
I was just lookiing at my car. I have the 850 with the holley supplied dual feel fuel line...it drops down at the stock angle about 4 inches. The extreme ends look to be lower than the carb flange on the manifold..I have the edelbrock RPM.
So I am wondering does the bottom of the turkey pan need some serious work or is the pan bottom contoured at all...IE flat bottom or will I be opening up here and there...I thought about the throttle linkage on the other side as well. Maybe in the worst case I can't use the nice feed line holley supplied with the carb and have to make something that does not drop down so far into the intake runners and stay above the carb flange line.
Tim
Old 03-04-2002, 10:35 AM
yes, the feed line maybe a problem, some i saw used short downward angle fuel line, the pan is flat with the bottom of the carb but does have some corners cut out to allow for lines in and out. you can probably make it work with very little trouble, if you ordered it from Enzo i heard it will take it back no problem. send me some pics if you get it on.
later Mike
Old 03-04-2002, 01:20 PM
Thanks for bearing with me on this Mike.
I appreciate someone who has seen one or knows about it.
Yeah the holley dual feeds come 4" out and down at 45 deg then are joined by a nice piece of braided line..at the front is the AN 6 male inlet.
*On a side note would you believe it has cost me $200 CDN just to run from the fuel pump up to the inlet of the fuel line supplied by holley. 3 feet of line 4 connectors/swivels. a coup[le pipe to an males and a nice inline billet filter.....And this was getting deals on all parts
After all this I want to be able to keep it...so you know why I ask about the pan....LOL
I think a way around it will be two oblong holes to allow the two feeds to go thru the pan bottom.
Yes sir ordered it from Paula at Enzos and she said they were backordered a little by 4 or so..She did say if I keep it nice and its a no go ..they will accept returns
Thanks again
Tim
Display Modes
HTML code is On
