SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 03-13-2002, 07:49 PM
Cobra Make, Engine: ERA 427SC FMS 351W
Default Eliminating 2nd Heater Hose Outlet on Water Pump
I have a 351W without a heater (and no plans to add one). I noticed the second heater hose on the water pump is plugged with a short piece of hose and metal bolt. Not liking points of failure and desiring the maximum cooling for Florida, should I run a heater hose from this second hose outlet to the manifold? Would this increase the cooling or divert water flow away from the radiator? The other heater hose outlet on the pump is the thermostat bypass hose.
Old 03-13-2002, 08:59 PM
SCOBRAC's Avatar
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
no.. just use a threaded plug to clean up the look. No advantage will be had from the hose being routed to the intake, and as you note. It is a potential point of failure.
Regards,
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
Old 03-15-2002, 06:46 PM
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Agreed. If you don't need the heater, plug the water pump inlet, and intake manifold heater water outlet with a brass pipe plug. Be sure to seal the threads with Permatex to avoid coolant weeping.
You may not need a heater in Florida, but you do have humidity, and windshields do fog up.
HTML code is On
