SUPPORT OUR SPONSOR
Old 03-16-2002, 07:41 PM
Post Dyno Results for 351C w/2V heads
Ran the engine on the dyno last week to primarily set up the fuel maps for the EFI. It has a pretty flat torque curve with 380+ ft-lb from 3500 to 5600 rpm, with a peak of 410 ft-lb at 5000 rpm.
HP was 257 at 3500 and peaked at 410 HP at 5500.
For all the engine stats and dyno results, go to
http://www.network54.com/Hide/Forum/...eid=1016333393
Dave
Old 03-17-2002, 06:23 AM
Dave,
I enjoyed your post. I have a carbureted Windsor block with 2V heads and am just putting the engine back together. I was looking at a similar cam, -561 vs. -551 except for the Windsor block. I finally decided to go with a Ford cam because the Crane was too much money, $250 for the cam, ~$350 for the lifters and amazingly enough ~$350 for the springs and retainers. I just didn't want to spend $1000 for a cam setup. The Ford A351 cam looks similar although the torque curve is not quite a flat on my Dyno 2000 and of course it's a hydralic cam rather than a roller.
It is also interesting that the dyno results matched your computer pretty well. My Dyno 2000 gave 457 hp @ 5500 and 478 lb-ft @ 4500 for the -561 cam with my setup. Looks that might be pretty close based on your experience.
Where is Clearville, PA?
Jack Z.
Old 03-17-2002, 11:30 AM
South central.
Closest towns of any size are Beford and Everett at about 30 miles, and Altoona and Johnstown at 60 miles.
Dave
HTML code is On
