SUPPORT OUR SPONSOR
Old 03-19-2002, 05:47 PM
fordracer's Avatar
Cobra Make, Engine: I had lots of little Cobras until Oscar the house thief stole all of them
Question Superformance Repairs
Has anybody had to replace a master cylinder on their Superformance. If so how was the job. Where did you get replacement parts ?
Old 03-20-2002, 01:56 PM
Cobra Make, Engine: SPF
Just call the SPF dealer. They stock an amzing amount of parts. If you can't wait on it to ship, ask them for the cross ref on it and you can pick one up at your local auto supply.
I haven't had mine off, but keep in mind that there is a removeable panel in the fender well right in front of it if you need it. I've had the panel off. Takes you right there.
Is your pedal sinking at a stop light?
Bob
Old 03-20-2002, 04:26 PM
Cobrabill's Avatar
Cobra Make, Engine: Superformance 427 Side-Oiler
I'll take the question one step further:Has anyone put a manual master cylinder on their Superformance?
The rest of the world can have their opinion about the United States just as soon as WE give it to them.
Old 03-20-2002, 05:07 PM
Cobra Make, Engine: SPF 2180, second one, Roush 427, first one SPF 746, 514 Big Block Strocker
It is not to difficult to replace the brake cylinder. Remove the front left tire and in the whell well there is an access plate, which can be removed. The access plate is bolted to the body with 4 bolts. The rest becomes easy with taking your time. Just as removing and installing sparkplugs on a SPF with a BB.
Enjoy
Old 10-27-2002, 10:10 PM
Club Cobra Member
Send a message via ICQ to BigJohn Send a message via AIM to BigJohn
I have a Classic Roadster, and I need to replace the master cylinder. It won't clear the mount bolts when I break it at the vacuum unit. There is no access panel in the wheel well. Do I have to put one in, or is there a trick to getting it out? I am going to try to unbolt the vac. unit from the firewall next, to see if I can tilt it up enough to clear, but that is a pain on a completely assembled car.
Thanks,
BigJohn
Old 10-28-2002, 07:02 AM
Lightbulb master cyclinder, and brake booster
bigjohn
been there done that. i have a 2001 CR with power brakes, the master cyclinder is large but it came out ok, you need to unhook the brake lines, and pull up and forward, it will come off, wiggle factor. now for the booster you will need to drop off the side pipe at the header to clear it and drop it out the bottom, tight but will fit, you can also as Don Scott over at the CR forum it is listed in the main area . was about 30-1hr job going slow not to hurt paint. let me know if i can help further
mike
Well officer.. It was like this.
Old 10-28-2002, 07:26 AM
Mr.Fixit's Avatar
fordracer,
If I remember correctly, the SPF master cyl is a mercedes unit. Probubly better to get it from your local SPF dealer.
HTML code is On
