Old 03-23-2002, 06:25 PM
Cobra Make, Engine: B&B 351W
Default Fuel Air ratio
Is there a good way to check fuel air mixture other then going to a dyno, I have a 351W with a 750 Edelbrock, I think I am running to lean do to the fact I can not keep it cool.any ideas would help.
Old 03-23-2002, 06:41 PM
Dave Samson's Avatar
Send a message via ICQ to Dave Samson Send a message via Yahoo to Dave Samson
Either hook up an air/fuel ratio meter to your Oxygen sensor, if you have one installed, or hook up a 0 - 1V DC volt meter to the sensor and watch the numbers. Readings as low as 0.2 V indicate very lean, up to 0.9 V indicate very rich, idle should be around 0.4 - 0.5 V. The readings are only meaningful once the sensor has heated sufficiently and gone in closed loop. I use both methods.
Let me have your email address, I'll send you an some interesting reading on this subject.
Cheers,Dave
Old 03-23-2002, 06:48 PM
Don't be foolish. Spend the money and put the car a the dyno with a wide range O2 sensor in the pipe or a 5 gas analizer to test the exhaust. Once you have it tunedup, buy an EGT gauge from Jegs or Summit and you can monitor your motor. Dyno is the best way to go. Call around for prices. About 100.00 per hour in the northeastern area. Good Luck Rick Lake
Old 03-24-2002, 05:42 AM
I am trying to learn as much as I can on the subject, evan before I have a dyno done.
bsuttonmci@att.net
Old 03-24-2002, 05:55 AM
Tommy's Avatar
Being a fan of both Cobras and Corvettes, I'm a member of both ClubCobra and the CorvetteForum. I found a very good tech article on tuning Holley carbs on the other forum. I don't see why the basics of carb tuning should be fundamentally different for Ford or Chevy V8s. You may find it helpful: http://www.corvetteforum.com/techtip...=108&TopicID=3
Tommy
Previously owned EM Cobra
Old 03-24-2002, 12:01 PM
Dont stop PLZ. I cant get enough info (every thing is good so far) please keep responding.
Old 03-25-2002, 08:08 AM
Cobra Make, Engine: SPF
Learn how to read your spark plugs. It isn't simply comparing your insulator color to a plug chart! You can determine how happy your engine is in both timing and mixture. Do a web search. Easier than me typing an essay.
bob
