SUPPORT OUR SPONSOR
Old 04-05-2002, 11:56 AM
Cobra Make, Engine: Hunter #28; 396 Cleveland stroker; more than 495 HP; TKO 5 speed
Default TKO shifter
What shifters are most using for a TKO? Recommendations
thanks
gn
Old 04-05-2002, 12:14 PM
Niles, Big consideration is your desire with respect to your desire for authenticity.
With that extent determined choose FIA or 427 style.
Then if that isn't a big deal, you have all the varieties of ripper mustang stuff. B&M Hurst etc
I bought the 427 raked forward style. Of course it has to be put together in terms of purchases
-Shifter handle
-Boot
-Bezel
-Shift knob
....get the drift?
Ripper's etc are fairly complete, but not cheap either
As for replica shifter there are varying degrees of quality and feel.
Tim
Old 04-05-2002, 12:19 PM
Post
Niles,
What don't you like about the stock shifter? How do you plan to drive the car? Aftermarket shifters will accelerate the wear on the syncros due to the quicker shifting action that they all offer. But most offer externally adjustable hard stops, which keep you from over-extending the shift forks. Personally, I added a Pro 5.0 shifter to my tremec (3550) but I haven't driven it yet . I have a stock T5 shifter handle mounted to it and it fits my car perfectly. I like the idea of the hard stops and am also used to a short throw shifter. But if I hadn't come across such a good deal on the shifter, I would have been quite happy with the stock TKO shifter on my 3550 (the TKO is the same as the regular 3550 shifter but with about a 30% shorter throw). I have driven a mustang with this setup and it was very nice. Plus, I don't plan on powershifting my car, but rather shifting with my wrist, hence the stock shifter would have been a-ok .
To answer your other question, there are several aftermarket shifters on the market. Do a search over on the corral.net and you'll find the most popular shifters are the Pro 5.0 and I believe the Steeda Tri-Ax.
Mike
Old 04-05-2002, 12:41 PM
wicked fast's Avatar
The longest build.....
Cobra Make, Engine: Mid-States, 428 Police Interceptor, TKO 5 speed, Jaguar rearend, Trigos, and Guardsman Blue!!!
Thumbs up
Niles,
Check out the photos in my gallery.
Tremec TKO with Cobra style handle from Enzo at FinishLine.
Fit perfectly, looks real, I mean accurate, I mean like a replica!!
If you were to die tonight, are you 100% sure
that you would go to Heaven ??
www.bluecarministries.com
Old 04-05-2002, 01:13 PM
Default Wicked fast
This is kind of funny but I had looked at your pics a while back before buying mine from the same supplier. great pics too!!
Your pic...
Your shifter
Tim
Old 04-05-2002, 03:05 PM
Wicked,
You're right--it does look and fit perfect ! Very nice indeed..
Mike
Old 04-05-2002, 04:47 PM
Bannon's Avatar
Cobra Make, Engine: Former Owner of both Superformance #2666 Roush 427IR and Superformance #1601 Ford Crate 460CI - 486 HP 510 ft\lbs TQ
Question Hybrid?
Isn't there a way to mate the shifter mechanism of a Pro 5.0 shifter with the authentic original style upper shifter handle and have the best of both worlds? I thought I had seen this done before.
JB
GUMBALL!
Old 04-05-2002, 05:00 PM
Cobra Make, Engine: SPF #1452 514" 429 SCJ
Send a message via Yahoo to LETSRCE
Hurst makes a shifter for the Tremec and the shift handle bolts right up to it.
Part # from summit....HUU-3915070 $175.95
I just installed it and it's a beautiful thing!
-Joe #1249
-Joe Cloutier
SPF #1452
514" 429 SCJ
Tupperware with an attitude!
Old 04-05-2002, 05:15 PM
Thumbs up
Yup, the shifter handle just bolts right to the top of the shifter with two bolts.
Old 04-05-2002, 07:24 PM
Question
I thought one of the advantages/upgrades of the TKO was that it had a short throw shifter ???
Old 04-05-2002, 07:30 PM
Nope, same rubber one you get in a GT Mustang.
-Joe Cloutier
SPF #1452
514" 429 SCJ
Old 04-05-2002, 08:35 PM
Lightbulb
The TKO does have a short throw shifter. It's about 30% shorter than the standard tremec 3550.
Mike
Old 04-05-2002, 09:58 PM
Then the standard one must really SUCK!!!!
-Joe Cloutier
SPF #1452
514" 429 SCJ
Old 04-05-2002, 11:21 PM
tim tim is offline
Cobra Make, Engine: Everett-Morrison, Boss 351 w/ TKO 5 speed, 94 vette suspension
The original tremec shifters work fine but the TKO does come with a shorter throw shifter than the regular 3550. As for aftermarket shifters all of them are 2 piece, the shift mecanism and the stick. You can remove and interchange shifter handles between any T-5 or Tremec 3550/TKO.
It was mentioned that the PRO 5.0 shifter came with positive stops. They are useless. I contacted TTC, the US distributor for Tremec transmissions and they said that the 3550/TKO have internal stops and to run the stops on the aftermarket shifter back away from the stick. They also said that installing an aftermarket shifter would void the warranty. After we determand that my transmission was no longer under warranty they said that most people from what they could tell were using the PRO 5.0 shifter but they would not endorse it.
After I got use to the new shifter I really like the way it performs. As for accelerated wear on my syncronizers, well that's why there brass so they will wear and not the steel gears.
DRIVE IT LIKE YOU STOLE IT!!!
It's a lot more fun that way.
tim
Old 04-07-2002, 06:17 PM
Default TKO Shifter
We had some very short shifters made for the Robnell cars, and they work great in most other replicas. If you want pics just email me at the office. Bolt direct to the Tremec, and sit right above the boot.
Dave
dshapero@houseofcobras.com
HTML code is On
