SUPPORT OUR SPONSOR
View Poll Results: ERA dead battery
charge battery in car 4 80.00%
remove dead battery to charge 1 20.00%
Voters: 5. You may not vote on this poll
Old 04-13-2002, 08:00 PM
Angry ERA battery charging
ERA dead battery- + pole under right front fender; should be able to charge battery by connecting + pole of charger to starter solenoid connection?? Any danger of damage to starter solenoid?
dr.j
Old 04-13-2002, 08:11 PM
Cobra Make, Engine: Genuine original Unique MotorCars 427 S/C, with a Genuine original Ford 427 Side-oiler.
Send a message via Yahoo to Cobranut
You can connect the positive side of the charger to any point on the positive battery cable. Just make sure it is the cable from the battery and not the one from the solenoid to the starter.
You can connect to ground anywhere on the cars chassis or the engine block itself if the neg term is inaccessable.
Keep in mind that your battery terminal connections must be clean and tight.
Good luck,
David
Old 04-13-2002, 08:12 PM
Cobra Make, Engine: ERA Cobra #273, 427 S/O, ERA GT-40 #2057, Excalibur Cobra.
Thumbs up
NOPE - -
JUST MAKE SURE YOU CONNECT IT TO THE BATTERY SIDE OF THE RELAY. CONNECT IT ALSO TO A GOOD CHASSIS GROUND.
BY ALL MEANS - PLEASE - MAKE SURE THAT YOU ADEQUATELY VENTILATE THE AREA BEFORE MAKING ANY CONNECTIONS. SULFURIC ACID FUMES ARE HIGHLY VOLATILE.
Y'ALL HAVE A REALLY GREAT DAY,
BLACKJACK
It's impossible to make anything FOOLPROOF - - Because FOOLS are so ingenious.
Old 04-13-2002, 08:40 PM
petek's Avatar
Cobra Make, Engine: CRL, 351W, Tremec TKO
"sulfuric acid fumes" ... don't you mean hydrogen gas?
Pete K.
Who is John Galt?
Old 04-16-2002, 01:29 PM
chopper's Avatar
Cobra Make, Engine: Previous ERA owner on break
You should be able to just connect the charger to the battery cable connected to the solenoid. However, if that bothers you, just disconnect the negative (ground) terminal from the battery and hook up the positive connection from the charger to the solenoid terminal and the negative connection of the charger to the battery negative terminal. That way, the only circuit being completed is the battery, just as if you removed the battery from the car.
Some folks drink from the fountain of knowledge; others just gargle.
Yesterday's flower children are today's blooming idiots.
HTML code is On
