SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 04-17-2002, 01:15 PM
renaissance man's Avatar
Cobra Make, Engine: SMC Motorcars 289
Send a message via Yahoo to renaissance man
Default Puke Tank and Radiator Caps
It's my understanding that you should only have one point of "pressure" in your cooling system? This being the radiator cap. The puke tank or "overflow" while it has a cap on it should have the bottom pressure seal removed.
1. True or False?
2. Is your pressure cap regulated at the radiator or the puke tank?
Co-founder of the Texas Cobra Club.
Dave "Ren Man"
Old 04-17-2002, 02:54 PM
Trans-Am Jim's Avatar
Send a message via ICQ to Trans-Am Jim
The puke tank should not be pressurized, and have a vent at the highest point.
Pressure is regulated at the expansion tank with cap. Cap has two-stage valving.
It works thusly:
when pressure in the expansion tank (in my case, could be a radiator) exceeds 18 lbs. (that's my cap's setting; others may differ) the cap opens and vents excess fluid into the puke tank. I have my puke tank overflow set up to dump on the headers, evaporating any fluid venting from the puke tank.
When the car starts cooling down after shut off, a vacuum is created, opening the secondary valve on my cap, allowing any fluid in the puke tank to be sucked back into the system. The puke tank allows this, because it is vented, not sealed.
Jimbo
Old 04-17-2002, 05:57 PM
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Ditto. Puke tank is for fluid overflow and is not pressurized. Got a plastic coolant overflow kit from local Trak/Pep Boys and a Stant 7 # cap. As engine gets hot, coolant flows out of the pressure cap on radiator into the overflow tank. As engine cools, vacuum is created, and coolant goes from tank, back into the radiator. Cooling system "breathes" and keeps air out of the cooling system.
Old 04-18-2002, 06:25 AM
Thanks guys,
That is exactly how I have it set up. Pressure only at the radiator. Just needed to verify.
Dave "Ren Man"
Display Modes
HTML code is On
