Old 04-29-2002, 08:01 PM
Campy's Avatar
Question Door Switches?
I am considering installing courtesy lights under my dash to illuminate the leg area. I would like to turn on the lights the conventional way with a door light switch. I have seen the alarm type switches but I would like something a little nicer. Something with a nice rubber boot, etc.
Does anyone know where I can find these gizmos?
Thanks Dudes
Old 04-29-2002, 08:30 PM
Cobra Make, Engine: Midstates, 427 Chevy (1969 L88)
My wife's 2001 Lexus ES300 uses a real nice booted door jam switch . Attaching screw is from the booted side , so it would be real easy to attach to any thing. Also it is mounted at opening end of door not toward the front. Lexus being just a overpriced Toyota. Toyota might even use the same switch. Check it out , might be just what your looking for. Happy hunting.....
Old 04-30-2002, 07:20 AM
Go to your local u-pull-it and you'll find a plethora of such goodies. And the price will be right, too .
Old 04-30-2002, 09:21 AM
Shell Valley should have them as an accessory item. Classic Roadsters does. Street rod electrical emporiums, Ron Francis, Street Works, Painless, etc., has them. Courtesy lights add a nice touch, and can be used for alarms as well. As an added touch, you can install a small LED by the ignition switch and headlights so you can find them in the dark. Remember, the courtesy light circuit is "complete the ground".
Old 04-30-2002, 11:16 AM
Campy's Avatar
Post Lights
Thanks Jack21
Old 05-01-2002, 08:17 AM
- But also remember that fiberglass does not constitute a ground. You'll have to run a separate wire from each switch's housing to a ground.
Bob Putnam
-E.R.A.-
