SUPPORT OUR SPONSOR
Old 05-05-2002, 08:51 PM
G.R.'s Avatar
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Question Using Monel wire for spinners
Have any of you used Monel wire to secure spinners on your wheels rather than s/s wire?
I used Monel to secure anchor thimble screws. It is virtually non-corroding, stronger than s/s wire of the same size and does not react with other metals. It is used in the marine and aviation industries for securings various parts.
If you have used it would you recommend it?
Thanks
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
Old 05-06-2002, 02:21 PM
Mr.Fixit's Avatar
Default safety wire
Stainless wire is the standard and all is good. This other wire you speak of, is stronger, less reactive, and made for the same purpose but in marine applications? It should be fine; if tensile strength, malleability, and all are suitable of course. I still haven't used up the last can of stainless safety wire I bought yet. Do yourself a favor and buy safety wire twisting pliers. Even the ones sold by Harbor freight for $15 work fine for wheel spinners. Once you start with the safety wire, everything is a candidate: header bolts, brake caliper bolts, you get the picture. If you need to drill bolt heads, get cobalt drill bits.
Old 05-06-2002, 02:36 PM
G.R.'s Avatar
Post
Fix-it
Got the pliers--handy little tool
Yes the Monel is aprox.048 in dia. Spent several years cruising, and have an anchor laying at the bottom of a bay in Mexico due to the s/s wire failing--long story--switched to Monel and never had a problem. I know there isn't much problem with reaction on wheels--but I do know that Monel is also used in some applications in the aviation industry as well as marine
Unless I hear different I will probably use Monel on my wheels spinners--I have about 50' left on a roll . It is more expensive than s/s
Old 05-06-2002, 02:40 PM
Mr.Fixit's Avatar
Sounds like good stuff. I'll have to buy some when the stainless runs out. I should spend more time at the marina to learn these things.
Old 05-06-2002, 03:38 PM
Specialk's Avatar
Cobra Make, Engine: 427 SC
Send a message via AIM to Specialk Send a message via Skype™ to Specialk
I believe Monel is a copper nickel alloy.
kris kincaid
Old 05-06-2002, 05:44 PM
Does any one know where One can learn the technique of safety wiring? parts,spinners.Thanks up front.
carlo
Old 05-06-2002, 09:45 PM
Cobra Make, Engine: Unique FIA
Carlo,
Look here http://av-info.faa.gov/dst/43-13/43.13-1b.pdf Go to chap 7 section 7. have fun. btw J.C. Whitney sells safety wire pliers for around $25
Steven
PS,
It takes a while to download this book, but it's worth it.
Old 05-06-2002, 09:47 PM
computerworks's Avatar
Talking ..my way was tougher!
Steve...
I was going to say that I learned safety wiring technique in the Air Force...
...but your way is easier, with less commitment
Old 05-06-2002, 10:23 PM
Hi Ron,
HOW THE HELL ARE YA DO-EN? I shudda done what ya did....wodda been a lot cheaper, and much more patriotic.
Steven
HTML code is On
