05-05-2002, 10:35 PM
15" vs 17"
I am trying to decide between 15" wheels or 17" wheels and I am having trouble so I come to you...
I have seen awsome results from James Baldwin's ERA http://www.baldwinology.com/
He has P&S 17's that look great and I am favoring
them.
But I know that 15" are original but the 17" are a better tire and I think that they look better, a much wider tire... 335-35-17!!!
I dont like the 17" that does not fill the wheel well but this tire looks great!
I am curious what the people think!
PS my ERA is coming in a few weeks!
05-06-2002, 03:11 PM
Cal
17" wheels
After driving lots of cobras with both 15" and 17" wheels, there is no comparison at all. The 17" wheel/tire setup performs so much better, all other aspects are secondary. Except looks and of course you can buy 17" tires with a good speed rating, unlike 15" tires. It's just that much more fun in corners, I sometimes take a cloverleaf offramp form the freeway, just to get back on a cloverleaf onramp. I love banked corners. However, I don't care for the "natural" center on PS wheels, you ought to polish or paint dark grey the centers. Make sure you get the right offset and tire size, it's no fun when the tires rub.
05-06-2002, 04:24 PM
I'm going with 17" to clear the front brakes. The 13" rotors I am using are too big to fit inside a 15" rim. I went with the big rotors because as with engine size, you can't have too much (braking) power!
I considered 16" wheels as a compromise but was not able to find tires in the correct sizes and speed ratings.
The current selection of 17" tire sizes, street/track variations and speed ratings is nearly unlimited.
If you must have the correct original appearance, use 15" wheels. For safety, most "gentleman's" racing and wide (pun) choice of rubber, go with the 17".
My 2 cents,
Tom
05-06-2002, 04:33 PM
WA
I am going with 17" because...
I wanted Z rated (186 mph) low profile Michelins, and the 17" was the minimum that would give me the proper look, and not affect gearing, vs the standard 15" and standard radial heights...
In other words, they come out about the same height/ & speed wise, but I get low profile high speed tires that perform well
05-06-2002, 04:48 PM
VA
Faced the same dilemma. The only things the 15's get you today is more original looks, and a little softer ride. But then, there was no such thing as original 351W's, 351C's, or 460's either.
Today, you can find 17" Halibrand look alikes at decent prices, and tires from mild to wild.
For the street, 17's are the way to go. You absolutely will not believe the difference in the way the car behaves on wet and dry roads, acceleration, cornering, and braking.
Something else to consider. A 17" tire isn't larger in diameter than it's equivalent 15". A 235/60R15 and 235/45R17 are the same outside diameter; 25 1/2". A 17" has no sidewall bulge like a 15" does. If your 15 rubbed just a tad, your 17 probably won't.
Look and see what todays performance street iron coming from the factory is running.
05-06-2002, 04:50 PM
I bought PS 17", had them powder coated to match my car, and am running Z rated tires....They look great, and even give the car a meaner look. I would go this way again in a heartbeat (no Chevy pun intended)
BigMike
05-06-2002, 04:53 PM
WA
Mine are Billet Specialties *Rebels*
05-06-2002, 05:54 PM
"Originality vs Practicality"
15-inch vs 17-inch
Big Block vs Small Block
Toploader vs Tremec
4-speed vs 5-speed
Independent rear vs Solid rear
Tubular Frame vs Rectangular Frame
Smith's vs Autometer
7 mpg vs 17 mpg
and so on, and so on, and so on, ...............................
So, which is more important to YOU? That is the bottom line.
Whatever you choose, congrats and best of luck with the new ride.
P.S. MOST owners spend VERY little time above 100 mph on the street so speed ratings are a non-issue.
Better to have and not need than need and not have!
05-07-2002, 11:10 PM
VA
Looks like I opted on the practicality side all the way down didn't I. But, I wanted a daily driver, not a trailer queen, so that's what I built. Didn't like the gears in the Tremec and used the T5Z instead.
Agree on the Z rating being meaningless as a matter of practicality, but the tire compounding and short sidewall is what makes the difference. Put a set of 15" T/A's or Dunlops on a Cobra. On a dry road you have a smoke machine. On a wet road you have a hockey puck. Swap for the 17's and the car just goes, stops, and corners. No smoke, no squealing. On a wet road, the tires hardly know the difference. If you believed you dared not drive this car in the rain, this will change.
05-08-2002, 12:55 AM
WA
How can a guy with a handle like GUMBALL not care about high speed tires!!?
I want them just in case I wanna go fast. In Montana and some other western states you can do this, although usually illegally.
Gumball, you fergot one option:....the 6 speed !
05-08-2002, 05:56 AM
SC
I really actually like my 15inch Trigos's, with Goodyear GT II's on them. The tires are cheap, last a long time, just replaced the fronts which were still useable, at 40K miles, on the third set of rear tires, because i run my car hard. I dont' suppose the quality of the "ride" is important in these sorts of cars, but mine is very comfortable, even with a 1150 mile run without turning it off. I have heard the 17's are appreciably stiffer. I like the deep tread of the GT II's, and living in SC, drive in rain all the time. I am careful because of my engine torque, but i never have a problem with a feeling of hydroplaning. Besides, for me, one of my main enjoyments of my SPF is it's original look. I realize most folks would not notice the difference in tire/wheels, as they only vaguely recall the car anyway. But when i am sitting at a cafe, and some gent takes his wife over to my nearby car, and explains to her "these are very rare, historic cars, and we are not likely to ever see another one again" it makes my heart warm. The GT II's are speed rated for a sustained 118 mph, and are safe for brief runs well above that, because the car is so light, that the tires with proper pressure don't flex much, and don't get too hot. I have run as fast as 12.0 seconds in the quarter mile on them, too.
I have recently acquired another set of Trigo's upon which i have mounted 15inch Hoosier race tires, because my son wants to someday run the long course at VIR, where we will be on the south course in several weeks.
One consideration is your diff ratio, with the 17's you probably need to go down somewhat to a 3.55 or lower because of the much smaller rolling radius of the 17's compared to the 15's, i am running 3.73's which are perfect for my combination.
I have all the performance i can safely use for the street, as i save my hard running for my occasional race track driving. To me, it is largely a matter of original looks, tire cost, and ride.
I myself am a Vintage sort of guy, i guess.
Hal Copple
Stroked SPF
"Daily Driver"
IV Corps 71-72, Gulf War
05-08-2002, 05:57 AM
Pa
Cobra Make, Engine: FFR2479K, 351W yellow/black stripes
I have 17" on my car. I love the look, and as everyone has said, the performance of the tires is fantastic. I have Firestone Firehawk SZ EPs, 275/40 in the rear, and they are awesome. They stick well and look great. The ride is stiff, but hey, it's supposed to be. I hear the wet traction is good, but since I have no roof, it'll never see rain.
I also autocross my car. Although my tires stick really well, I must say that since my last car had Kuhmo Victoracers, and street tire (regardless of size), can't hold a candle. I wish there was a way I could have a set of those too.
Steve
05-08-2002, 12:04 PM
B in B,
Gumball? ......................... just a fan of the movie.
Yes, I forgot many options that would make the car more user friendly. The original cars were designed to race, that is all. It is the most impractical car that comes to mind. And THAT is the allure for me. My car doesn't even have a fuel level gauge for goodness sake!
Now, tell me more about the roads in Montana with no speed limits. It sure is hard to find anything like that around here in the Gay Area. The track is really the only safe place to have any fun above 100 mph, except for the occasional burst.
BTW........ When is your car due? I can tell by the furious pace of your post activity that you are chomping at the bit. Hope it arrives soon and is everything you hoped for. (that 6-speed sounds nice)
05-08-2002, 12:28 PM
Cobra Make, Engine: SMC Motorcars 289
17"...no doubt. You can see my car by clicking the link on the left.
Co-founder of the Texas Cobra Club.
Dave "Ren Man"
