SUPPORT OUR SPONSOR
Old 05-26-2002, 02:03 PM
Default 289 ida idle jetting
Could someone out there advise of where I'm going wrong with my idle circuit? I'm running a 289 .030 over with 10:1 compression. I've got a solid cam with 238 degrees duration. I'm running 48 idas with : idle jets .60 idle jet holder 120, main jets 155, air correctors 210. Chokes are 37mm. The idle jets are engraved with only one number, 60, not 60 f8 if this makes a difference. The floats are o.k. and at the same level. The carbs flow the same amount of air and the linkage appears to be correct.
The car runs great above 2900 rpm, but stumbles badly when pulling out, or trying to launch at about 2500 for a drag race start.
Any help would be greatly appreciated,
Thanks
tblackgt350
Old 05-26-2002, 02:31 PM
To lean on air corrector,try 150/155,have same combo but with early fully ported original GT40 head (C6FE)flowed at .600,IN 253 EX 202,my IDA set up is with F7 ,155 main/145 air,regards,Bernie
Bernie 289 FIA
Old 05-26-2002, 04:04 PM
289 FIA Fan
Thumbs up To Quote Cal Metal
"Contact Enzo at Finishline, he is the master of Webbers!"
Did I say it right Cal?
Dave Lowell
Old 05-26-2002, 06:03 PM
Cobra Make, Engine: ERA #122 (Sold) : Ford GT #484 Heritage Edition; 2008 GT500 Red/Black
You didn't mention what you bypass valves are...they would create the situation you are talking about because you are dumping too much gas into the carb.
Matt
2006 Ford GT #484 Heritage Edition
2003 Hummer H1 OpenTop
2003 Hummer H1 Wagon
Old 05-27-2002, 10:29 AM
The valves at the bottom of the float bowls are.50, the emulsion tubes are F7.
Thanks, tblackgt350
Old 05-27-2002, 10:30 AM
Default 289 48 ida idle jetting
Thanks, tblackgt350
Old 06-05-2002, 10:08 PM
Original Shelby Owner
Go to a 55 bypass valve. How are you checking your float height?
HTML code is On
