SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 06-02-2002, 05:09 PM
bran3b's Avatar
Cobra Make, Engine: Midstates, 460
Question 460 dipstick question
What are the measurements from handle to full and add marks on the dipstick? I have a 460 with a stock front sump pan. I have a modified 351 dipstick which was made by following the directions of a local Ford performance shop. Recently I noticed the oil guage quiver under braking. This looks like bubbles in the oil lines to me. After seeing this I parked the car, and will do a oil change and look for debris which could indicate a blockage somewhere. Before I put the car back on the road I want to make sure that I am giving it enough oil.
Thanks for the help,
Bran
"Clowns to the left of me,
Jokers to the right..."
Brandon
Old 06-02-2002, 06:59 PM
bran3b's Avatar
I forgot to mention, for some reason I can't find a 429/460 front sump dipstick in Colorado. I can't even find one in a salvage yard.
Thanks again
Brandon
Old 06-02-2002, 07:13 PM
Cobra Make, Engine: Home built, supercharged 544cu/in automatic
Brandon- stock 460's generally hold 6 quarts with the filter . Next time you change the oil after running your car mark your dipstick at that level. I also found that 460's run a bit better with a extra quart but they tend to blow/throw it out over 1000 miles or so.
You also need to upgrade that stock pan for a performance pan even with stock engines in Cobras. Cheap insurance.
cobrashoch
Ron Shockley
Old 06-02-2002, 07:23 PM
bran3b's Avatar
Thanks Ron, I will take your advice on how to mark the dipstick tomorow and replace the pan asap.
Thanks again
Brandon
HTML code is On
