Old 06-05-2002, 08:11 PM
Question Rear Pin Drive Spindle Nut
I am trying to remove the spindle nut. I have a Jag rear and the univesals are bad. I have pin drive spindles. I have removed the cotter pin but cannot break loose the spindle nut.
How do you break the spindle nuts loose?
Old 06-06-2002, 04:30 AM
A large air wrench. The tightening torque of the axle nut is 140 lbft, so it will probably take more than that to loosen it.
Bob Putnam
-E.R.A.-
Old 06-06-2002, 05:24 AM
Thanks for the reply.
Without air tools or a compressor, what else are my options? Can the universals be replaced without taking apart the spindle?
Old 06-06-2002, 08:23 AM
I don't think it's possible to change the u-joint in situ.
Warning! This is not a sanctioned method!
While the car is on the ground, remove the wing nut. Then use a long breaker bar to remove the nut. Orient the breaker so that you're pushing toward the ground, not pulling up. That's to add traction to that wheel, rather than reducing it.
Bob Putnam
-E.R.A.-
Old 06-10-2002, 04:12 PM
Thanks for the info. I did remove it with the aid of a mechanic with an air impact wrench. Now the question is: The mechanic seems to feel that if it torqued to 140lbs, it will crush the bearings. I did not see it apart. What stops it from being crushed, as he feels?
Old 06-11-2002, 04:09 AM
Your mechanic has apparantly never worked on Jag hubs. See these hints
Bob Putnam
-E.R.A.-
