SUPPORT OUR SPONSOR
Old 06-11-2002, 12:04 PM
Default Quick Disconnect Steering Wheel
Am thinking of using a quick disconnect steering wheel to aid in anti theft. Is anyone using such as setup? Make and price?
Thanks
Venom_S
Old 06-11-2002, 05:13 PM
Bryan Wilson's Avatar
Cobra Make, Engine: Real: Southern Roadcraft, SRV8, 351W stroker
Lightbulb Removable steering wheel
Venom S
My car has the early Jag XJ6 steering column complete with turn signal switch and collapasable mechanism. Behind the hub boss there is a large nut that when loosend off allows the steering wheel to be moved back and foward. If this large nut is completely undone the whole steering wheel and boss can be easily removed. A handy anti theft method.
Regards,
Bryan Wilson
COB-66 Young at heart old fart.
Don't drive faster than your guardian angel can fly.
If it doesn't matter what gear your in you have enough torque.
VK3KDN
Old 06-11-2002, 05:23 PM
bonyhadi's Avatar
Cobra Make, Engine: ERA535 with 427FE s.o.& toploader
Send a message via AIM to bonyhadi Send a message via Yahoo to bonyhadi
I had one, it wasn't by design, just a loose spleen connector, suggets you all check yours.
Need more horsepower, raki and where in the hell did The REDHEAD go off to?
Old 06-11-2002, 05:59 PM
STG STG is offline
Default Try Finish Line Motorsports
Finish Line is a Shelby dealer located near SAI in Las Vegas. They have a quick disconnect unit. Also, try some of the imported car parts dealers. Aftermarket wheels like Momo and some german brands are available with quick disconnect hubs.
Old 06-11-2002, 09:16 PM
I am working with a racing team for the summer and I will check what unit they run tomorrow. It is a very stout unit with no slop.
2500 Pounds of steel, rubber, and fire. AAAHHHH!
Old 06-12-2002, 02:31 AM
750hp's Avatar
I'm using a Rebco brand splined QR hub with the flange release mechanism. Of the brands I was able to see for myself, the Rebco splined hub had the tighest feel to it. Other brands had "spline rattle" which would make the car feel as though it needed a steering rack rebuild...
I also prefer the flange type mechanism over a spring loaded release pin. Personal preference I suppose...
Price? I bought it here in Australia, but I think it's pretty cheap in the US compared to SPA or other similar brands.
Craig
Old 06-12-2002, 04:06 AM
I've found that there are unpleasant tradeoffs in the choice of adapters. The spline-type tend to be tighter, but the steering wheel is a PITA to replace to its original position. I haven't found a hex-type that was slop-free, and even the splined ones are not perfect.
Bob Putnam
-E.R.A.-
Please address parts inquiries to eraparts@sbcglobal.net
Old 06-12-2002, 05:37 AM
Cobra Make, Engine: Contemporary, 427 EFI; CAV GT40, 427W
Is the REBCO a spline type or hex type?
Thanks
Thanks
Gary
CAV GT40 Dealer
www.2gmotorsports.com
HTML code is On
