SUPPORT OUR SPONSOR
Old 07-02-2002, 11:40 PM
ronzara's Avatar
Cobra Make, Engine: Everett-Morrison 351w assembly STILL in progress
Send a message via AIM to ronzara Send a message via Yahoo to ronzara
Default Hood Scoop Cut Out ?
What is everybody doing with the opening in the hood scoop??
Do you cut through both the inner and outer panels? Seems like if caught in the rain, the air cleaner would be sucking in water,....
I've seen some with screen in the opening,... any recommendations??
I need input on this,... before I bond the sections together. Thanks.
RZ
Ron Zara
ronzara@hotmail.com
1. "Putting a Chevy Motor in a Shelby Cobra is like CUSSING IN CHURCH!"...... ME
2. "Friends Don't Let Friends Drive Junk"....
Old 07-03-2002, 03:32 AM
Cobra Make, Engine: Classic Roadsters, 393 stroker, Tremec 3550, about 425 hp, MDA GT40 289
Hey Ron,
Mines cut out open to the elements, and actually, every Cobra I have ever seen has been the same way. I don't think most people drive them in the rain, but I'll bet you could get something like a K&N filter which requires a little oil be sprayed on it. At least with some oil, the water may dissapate.
Jim Downard
P.S. The classic roadsters on e-bay wound up going for $8500.
Old 07-03-2002, 08:26 AM
Mr.Fixit's Avatar
Yes the hood scoop should actually be open without any screen. More water will hit the aircleaner in the rain from water getting vaporized through the radiator and fans than the tiny bit that passes through the scoop. Don't worry it's only water
Old 07-05-2002, 02:20 PM
ronzara's Avatar
Ok. Thanks guys.
Here's another Question for you>>>
I have made the cut outs in the inner and outer hood panels. They look good....
I set them on the body... looking through to the air cleaner, it looks completely crappy in there, is there a way to finish the inside of this area to make it smooth and clean??
If so, When (before or after bonding the panels)and how should I do this?
I am at the point in my build that is pretty much unwritten in my EM Manual.
I guess from here on out it's all a matter of personal devotion and taste,....
Thanks
RZ
Ron Zara
ronzara@hotmail.com
Old 07-08-2002, 07:28 PM
Default Hood
Hi Ron,
My hood scoop is open, but to make it look better I made and blended in a fiberglass strip to the inside edge of the top panel so that the scoop opening isn't just a hole looking down to the engine. Looks pretty good.
Steve
HTML code is On
