Old 07-20-2002, 06:20 PM
bran3b's Avatar
Cobra Make, Engine: Midstates, 460
Question Compression ratio?
I have a 460 with a 9.3:1 compression ratio using 93cc heads. How can I figure out what the ratio would be with 75cc heads? How far can I go (10:1, 10.5:1...) and still run on pump gas at 6000' altatude?
"Clowns to the left of me,
Jokers to the right..."
Brandon
Old 07-20-2002, 09:42 PM
jdean's Avatar
If you now have 9.3 with 93cc, then going down to 75cc would result in 10.92.
Above 4,500 ft. and you can basically reduce effective CR by one, so the 10.92 would be 9.92 or less.
Other considerations are whether the replacement head is aluminum. If so you can run about .5 more CR than an iron head without detonation.
According to Pat Ganahl in his Ford Performance book, the 460 heads are able to get away with a bit more CR than expected.
It appears that with your altitude, you would be safe with 75cc heads on pump gas.
Hope this helps.
6th generation Texan....
Old 07-21-2002, 05:30 PM
pbrown's Avatar
Cobra Make, Engine: Franklin Mint 427S/C replica
Default good auto math site
http://www.bgsoflex.com/auto.html
Enjoy,
Patrick Brown
http://www.uniquecobra.com
Old 07-21-2002, 10:08 PM
Mr.Fixit's Avatar
before you switch heads, make sure your new combustion chambers will accomidate the piston dome shape, and recheck for valve to piston clearance.
