SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 08-05-2002, 07:46 AM
OZCOBRA's Avatar
Post Quicklift Dimensions......
Has anyone the CORRECT dimensional drawings for QUICKLIFTS ? i am wanting to make a set for my car.
When mounting are they facing in or out??
Thanks Paul
Old 08-05-2002, 07:55 AM
renaissance man's Avatar
Cobra Make, Engine: SMC Motorcars 289
Send a message via Yahoo to renaissance man
Paul,
Go to www.kwiklift.com Don't know about the demensions but the price is right! I would think the only way is with the ramp facing "out" so that you can drive on and off.
Co-founder of the Texas Cobra Club.
Dave "Ren Man"
Old 08-05-2002, 08:08 AM
Ron61's Avatar
Default Re Kwiklift
I got one of their first sets and I just went out and measured them. The length of each ramp is 14 foot 10 1/2 inches with the back stands bolted on. The ramp with is 16 inches. Height is about 19 inches when both legs are down and that gives me around 25-30 inches under the car. The width can be changed to fit different cars. I have mine with the end you lower facing out as I back up onto them in my garage. I have really liked them and they are great when you don't have enough height in your garage for a regular electric lift.
Ron61
Ron Widener
Old 08-05-2002, 08:15 AM
Cobra Make, Engine: Self Built, 427 USRRC, 427FE, Toploader
Oops,
I'll just delete the answer, I first saw the post and thought you meant "quik jack"s like works with the lift frame like the racing COBRAs used. Sorry, I no nothing about the lift system as noted.
grumpy
Old 08-05-2002, 08:18 AM
OZCOBRA's Avatar
Question
Sorry guys a bit of a misunderstanding,it must be that Aussie accent.
I'm actually refering to the car bumper lifts ,i've only heard them refered to as quicklifts, am i correct in calling them that?
Thanks for your previous replies!! Paul
Old 08-05-2002, 08:51 AM
Default "qwik jacks"
do you still need the drawing? have you fabricated the frame extensions yet? if so you will need to make the plates to bolt them to compatible as far as dimensions. there are two types, the kit car version and the 289/427 kind that fit the offset holes on the CSX chassis, which one?
grumpy
Old 08-05-2002, 09:02 AM
Clois Harlan's Avatar
Default Jacks
OZ,
If Bob Putnam doesn't jump in here and give us a set of blueprints. I will take a digital pic of mine against some 1/8" graph paper so you may have some idea if their deminsions.
Clois
"Let's roll"
"Be part of Something Good
Old 08-05-2002, 01:22 PM
Mr.Fixit's Avatar
I think that SPF has the nicest looking "bumper jacks" out there. They appear solid but are 2 welded pieces. Not the flimsy bent pieces found on some. Shape is pleasing as well. As for in or out, I assume that in was the intended direction (they seem to be cut to follow the body lines), but pointed out was easier to access and perhaps quicker. Most guys point them out.
Old 08-05-2002, 03:31 PM
rdorman's Avatar
Renegade Nuns on Wheels
Default Are you sure???
From what I have seen and heard you may be able to lift the car with a quick jack, but do you want to? Was the mounting and hardware made to support the weight? If and when then flex a bit, what are they going to do the the body? I have seen a number of pictures of originals used for racing where the hardware and body around the opening looked all askew.
Aside from that, a big 'L' triangulated with rollers that will take the weight on a axle through the tube on the ground. The lever as long as you can pull it. Still probably better put to guys on it to pull it up. That is the way I have seen them.
We used some in formula racing but they lifted on a flat plate on the tub. Different geometry as well.
Have fun!
Old 08-06-2002, 02:23 AM
OZCOBRA's Avatar
Thumbs up
thanks guys ,
grumpy your a bit quick,they are exactly what i was after.
Clois, if bob doesn't jump in ,your pics would be great,thanks.
Mr.Fixit, I agree whole heartedly a solid ,well shaped welded item is a must and thanks for the directional info.
rdorman, purely non functional and thanks for the history.
Regards to all.....Paul
Old 08-07-2002, 04:22 AM
The front and rear quick jacks are different in shape Paul, and the correct way to mount them is with bolts on the outside. I have a beautiful looking set if you want to borrow them for a pattern but engineer doesnt like them, something about not mixing well with skateboarders when you run them over!
All torque, no traction!
Anything is possible (if you can justify throwing bucket loads of money at it!).
Old 08-07-2002, 06:18 AM
OZCOBRA's Avatar
Thumbs up
ANDY I'LL TAKE A LOOK AT THEM ,PERHAPS YOU COULD LEAVE THEM WITH DOUG OR I'LL CATCH YOU FOR PIZZA.
PAUL
Old 08-08-2002, 05:41 AM
Sounds good mate, I'll bring the quick jacks, you bring the pizza. Give me a call when you are next going to be at the factory!
Old 08-09-2002, 11:09 AM
OZCOBRA,
Did you get the drawing of the qwik lift jack brackets? The drawing is full scale but dimensions are in millimeters. The scale bar is in FT/INCHES and can be used to zoom up and down on a copier.
grumpy
HTML code is On
