SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 08-24-2002, 08:05 PM
mg2166's Avatar
Cobra Make, Engine: Everett Morrison, 351W
Question Lighting Question
The amber lights on the front of my Cobra have a dual filament (high & low). These lights are used for turn signals and parking lights. However, after hooking everything up and testing, the left and right lights operate opposite from each other. The right light is bright when I use the turn signal, and dim when I use the parking lights. The left light is dim when I use the turn signal amd bright when I use the parking lights. Which is correct? Bright turn signal or bright parking light????
Old 08-24-2002, 08:34 PM
427sharpe's Avatar
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
The turn signal is brighter. you have one light wired backwards, or a bulb not indexed correctly. Even though the bulbs have a pair of guides to index them correctly, you can cram them in and get the bulb backwards.
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
Old 08-24-2002, 09:07 PM
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Ditto the above. Turn signal is bright, parking is dim.
These Lucas lights are relatively small, and benefit from a brighter bulb. wire-works.com offers a bright lite for these which show up a lot brighter in nighttime driving.
Old 08-25-2002, 06:27 AM
mg2166's Avatar
Smile Thanks
Thanks for the info.
Jack, do you havea part # for the brighter bulbs?
Old 08-25-2002, 12:08 PM
Go to www.wire-works.com, bulbs and sockets. Bulb part numbers are 1077 (dual filament, you'll need 4. Front park and turn, rear tail and stop), and 1015 (single filament, you'll need 2. Rear turn). Substantial improvement.
HTML code is On
