Old 08-24-2002, 08:00 PM
Cobra Make, Engine: CSX Cars
Question SPF Speedometer
I was out for a little drive and the speedo was working fine until I went over 100MPH. Now it is bouncing around, did something come apart? Any help would be great...........What should I look for.
Old 08-24-2002, 09:48 PM
shark's Avatar
Cobra Make, Engine: Superformance Brock Coupe
Mine also bounces somewhat. I've been advised by my builder to check the speedometer knurled connecter behind the speedo - the connector takes a fairly aggressive turn/angle and loosening the connector very slightly seemed to unbind the cable - it still bounces - just not as much. Try loosening first and test driving - then maybe tightening. Let us know what you find - you're not alone.
Anyway, over 100 MPH dont' be looking at that gauge - looking ahead might be safer
Be safe -- Mike
Old 08-25-2002, 02:24 PM
I was able to get under the steering wheel (not easy) and found that the connector was not tight. So I gave it a little muscle and will try out later today.
I was looking ahead, my car has the Corvette windsheild readout!
Old 08-26-2002, 08:12 AM
Mr.Fixit's Avatar
Make sure there are no tight bends in the speedo cable. Tight turns can cause this.
