SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 08-27-2002, 11:39 PM
Default polishing trigos--help--tips
what have you used---polish/buffing wheel attachments?
and where did you buy them? technique?
i dont want to trial and error--what has worked best to get your wheels looking like new?
thanks
steve hamm
spf1383
Old 08-28-2002, 12:15 AM
Rick Parker's Avatar
Default Wheel Polishing
I made a mandral out of 3" round stock to fit in the center of the center lock wheel and spin it in a large lathe. Then used several various grits of sandpaper and ultimatly "Mothers Aluminum Polish" to bring out a brilliant shine on the outer lips and the area connecting to the spokes. I was fortunate to have access to a large lathe, it helped eliminate alot of "elbow grease"!!!
10-15 minutes each.
Rick
Old 08-28-2002, 08:59 AM
Mr.Fixit's Avatar
Some things you can't pay me to do, polishing aluminum wheels is one of them. I send them out to a local polisher who does them cheap and quickly to a standard I would not be able to reproduce myself. Once they're shiny, it's pretty easy to keep them that way with mother's.
Old 08-28-2002, 09:51 AM
cobrajeff's Avatar
Default Polishing aluminum wheels is a lot of work
I'm with Mr. Fixit on this one - I had access to a large lathe, a spare hub to set them up on, and a large variety of different grades of sandpaper and emery cloth. I spent HOURS on my wheels, and could not get them like I wanted.
The surface MAY have been a little courser than normal, as I had the wheels machined to create a deeper area for polishing. I ended up sending them out, and they STILL didn't come out as smooth and shiney as I wanted. I sent them back again, and after the third polishing, I got what I wanted.
For maintainence, I have found that "Mother's" wheel polish is coarser than "The Treatment" brand. I use Mothers to start, and The Treatment to finish. Any of you who happen to polish a set of real Magnesium wheels instead of Aluminum wheels will especially notice the differnce.
Regards,
Jeff Burgy
CobraJeff
ERA P 202
Old 08-28-2002, 04:46 PM
Don Don is offline
Consider using " Wenol "
www.wenol.com
Old 08-28-2002, 08:32 PM
gsharapa's Avatar
NeverDull
Gary
CAV GT40
HTML code is On
