SUPPORT OUR SPONSOR
Old 09-13-2002, 05:04 PM
mike knight's Avatar
Cobra Make, Engine: spf 1837 408w 93mm turbo
Send a message via AIM to mike knight Send a message via Yahoo to mike knight
Default engine care
i have a 429 on an engine stand. i plan on putting it in my car next year. i currently have a 351 w in the car. my question is can i turn the 429 over to keep the engine lubed by direct battery jump to the starter with the plugs out and squirt some oil in the cylinders. any recommendations would be appreciated.
BAD ASP
spf 1837 408w intercooled turbo t56 viper 6spd
95 mustang cobra 408w vortech t trim supercharger
71 torino cobra 429 scj
66 ford galaxie 7 liter
68 buick wildcat 430
Old 09-14-2002, 12:24 PM
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
If this is a fresh build, not a good idea. You'll wipe the break in lube off the cam, and the cam may fail when you start it up for the first time. If using roller lifters, you should be OK, no cam break in. If this is an already running and broken in engine, you should be OK there too. I'd just hose it down with WD40, crank it over by hand once to lube the cylinders and lifters, then put a plastic engine bag around it to protect it.
Old 09-14-2002, 01:14 PM
sounds good thanks jack
BAD ASP
HTML code is On
