Old 10-21-2002, 06:54 PM
Default Quick Brake MC question
I have a tandem system brake MC. Its floor mounted with 2- 4 oz.remote reservoirs.
I received no info or manufacturer name with it when I got my half built roller.
Is the front most port to go to the front or back and ditto for the rear most port on the MC??
Thx Tim
It looks like this configuration, except it has remote reservoirs which are both equally sized.
Old 10-22-2002, 04:57 PM
Seeing as how I recieved no response to my question on my brake MC I thought I would post what a wilwood tech gave me today.......
"The port closest to the mounting flange has more volume, this would go the front brakes"
Now we all know
cheers
Tim
Old 10-22-2002, 05:06 PM
Cobra Make, Engine: Contemporary CCX33868 Sold. Just "playin' the boards now."
Right on Tim. Be sure to put a coil in the lines just below the MC when you install. Helps with air in the lines. You can and should also bleed the MC/reservoir line before hooking it up to the main brake lines.
Al
"If some is good, more is better.
And too much is just enough."
--Carroll Shelby
Old 10-22-2002, 10:23 PM
Hi Al
Thanks for the response
I have the floor mounted pedals and MC. Because we are already down at the fllors frame there is not the greatest room for much except a very tight radius loop or loops.
Do you mean a single loop on the vertical plain at each port?
I will be mounting 2- 2# residual valves as well.
I always thought that the loop/s were for vibration sake?
How does the loop help out in the air aspect?
I am in the process of retubing the MC with emphasis on getting a firm pedal.
Thanks for the input
Tim
Old 10-23-2002, 02:30 AM
found this site later tonight
http://www.howstuffworks.com/question453.htm
Tim
