February 2026
Old 11-17-2002, 12:52 PM
Back in Black's Avatar
Question A useful bolt on...?
I just noticed these bolt-on electric motors which eliminate the need to power your water pump off of the crank...thereby supposedly freeing up horsepower for about $80...are they useful?
The reason I ask is I have a beautiful new high polished water pump coming on my 514 and I don't want to give that up for a simpler electric water pump..unless this is a bad idea...:
http://www.jegs.com/cgi-bin/ncommerc...34&prmenbr=361
Old 11-17-2002, 12:59 PM
kountzecobra's Avatar
Most are for drag racing use only. In other words, no continuous use. Some may be more reliable.
Old 11-17-2002, 03:07 PM
I've found a couple of electric water pumps made for street use, but the cheapest is more than $250. Even the ones intended for drag racing are about $200.
Perhaps this is only a motor to drive the normal water pump?
Bob Putnam
-E.R.A.-
Old 11-17-2002, 03:16 PM
speed220mph's Avatar
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
Won't be long that most exterior engine accessories will be electric-motor drive on production vehicles to reduce parasitic power losses, so expect the availability of such motors to improve. As for prices, that'll probably take a while to stabilize.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
Old 11-17-2002, 07:20 PM
Smile Bob:
Yah, it's a discrete motor unit with a mounting bracket...powers the standard water pump I have now...this why I thought it might be an easy install and would let me keep my high polished WP as is.....
The only question is...is this Edelbrock unit something I can count on for long term street use, or is it as kountzecobra suggets, just for drag racing, etc...?
Also...I was wondering how much HP a belt/crank driven water pump takes/uses ?
Old 11-18-2002, 07:03 AM
BiB
A good pump like a Stewart stage 4 with the CNC'd impeller will require less than 3hp @ 4500 rpm and flow 160 gpm.
Old 11-18-2002, 09:02 AM
Cool Since I will have over 600 HP..
It hardly then seems worth the trouble, just to pick up + - 5 HP....
Old 11-18-2002, 11:09 AM
Mr.Fixit's Avatar
It is for drag racing only, where it will free up some HP, but only run for a short interval. You wouldn't feel a 25 hp increase, you would need timing equipment to see the increase. Your car already has a bunch of goodies, I suggest you drive the snot out of it before "upgrading" anything else.
