Old 11-18-2002, 08:14 AM
bly bly is offline
Angry oil leak
I still have an oil leak at the base of distributor. Engine is a 351W. I have already put a new o-ring on, and put a gasket on base of distributor, sitll leaks. Distributor is a new oem unit. Dont know what else to try, Does anyone have any suggestions, I would greatly appreciate any help.
Old 11-18-2002, 09:21 AM
speed220mph's Avatar
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
I 'll bet your oil leak is coming from the front intake-manifold end gasket. Where the gasket makes the turn around behind the distributor is notorious for pinching out and leaking. A leak here will run down behind the distributor, thus giving the false impression oil is coming from the distributor base.
I resort to using "gorilla snot", officially known as 3M Weatherstrip Adhesive, to glue the gasket to the block and keep it from pinching out as I torque down the manifold. So, take a good look at this area before you go any further.
Good luck
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
