SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 12-01-2002, 10:05 PM
Talking Rear brakes, etc.
I have at one time or another done about every r&r you can do on my Unique. Installed the rear emergency brakes with the body on. I do not know that I would want an access through the cockpit since you can get to everything pretty easily from underneath....and I do NOT have a lift. Just four good old jack stands and a BO floor jack. I have a toploader in my car and I truly believe you can reach everything on it also. The catch maybe lining up the tranny and not knocking out the pilot bearing on the reinstall.
Now I am not going to tell you that working on the brakes in the rear doesn't get a little frustrating turning those bolts about 1/16 of a turn with your arms over your head....(boy was I sore) but it is possible. I have also done a r&r on the rear rotors and brakes on both sides to work on the rearend.
PS..I have seen an access panel cut into the transmission tunnel by Alan or Maurice. I think that they did it at the request of the buyer to have access to the shift linkage (you know those spring clips on the linkage are like a bullet in a box when you are on your back and it decides to go a flying)....
Good luck and remember a lot of water is sprayed into that area, so your access panel will need to fit fairly snug to retain the water resistance..(no cobra is waterproof ..just water resistant.)
Display Modes
HTML code is On
