Old 12-02-2002, 01:27 PM
Cobra Make, Engine: SPF - 427 Stroker
Default Transmission Rattle
When I get my car up to around 4000 revs I develop a really loud rattle coming from right under the shifter. I removed the rubber boot and nothing was loose. The sound is almost like a washer that is vibrating, loud enough to hear it over the wind/exhaust noise at 80mph...If I grasp the shifter really hard when it is doing it > it stops...Any ideas ??
NEVER LIFT
Old 12-02-2002, 01:30 PM
Original Shelby Owner
What kind of transmission?
Old 12-02-2002, 01:31 PM
...sorry - TKO
NEVER LIFT
Old 12-02-2002, 03:17 PM
Is this happening with the car in neutral or does the driveshaft have to be turning? If the latter, could the driveshaft be out of balance?
Bob Putnam
-E.R.A.-
Old 12-02-2002, 03:36 PM
Only when the car is moving and under power does it happen...But what is strange is that if I grab the shifter really tight it stops...
NEVER LIFT
Old 12-02-2002, 04:21 PM
HighPlainsDrifter's Avatar
Thumbs up
Hi,
Check you tranny mount,the bolts to the frame could be loose or mount broken. Look for anything else rubbing up or near the tranny, speedo cable,E brake ,etc.
Perry.
Old 12-02-2002, 06:49 PM
Sounds like a loose bolt to me, hopefully nothing is broken but I gotta get under 'er and check it out...Thanks guys / Perry...
NEVER LIFT
Old 12-02-2002, 10:04 PM
Mr.Fixit's Avatar
You may have split the plastic cup that the shifter "ball" sticks into in the tranny. Or it could be a thousand other things.
Old 12-03-2002, 08:33 AM
I had been out of town for a week and when I got back there was a small (size of a nickle) puddle of red tranny fluid under it. Any ideas if this could be a part of the noise or another unrelated prob ?
Sorry, would have said this earlier but I just realized it last night.
NEVER LIFT
