SUPPORT OUR SPONSOR
February 2026
Old 12-03-2002, 09:33 AM
427 S/O's Avatar
Default gas gauge/sending unit
Gas gauge jumps back and forth while driving?, checked all connections and everything is fine. When car is parked, I can grab roll bar and shake, same thing happens?.
Is there some type of resistor or whatever, I can install between sending unit and gauge to slow reading?.
Thanks in advance.
Perry
Old 12-03-2002, 09:39 AM
Could it be a problem with the baffling in the tank? I frankly have no idea, that's just one thing that came to mind.
2500 Pounds of steel, rubber, and fire. AAAHHHH!
Old 12-03-2002, 09:46 AM
427 S/O's Avatar
Only side to side baffling, Oh yeah, they
are SW universal sending unit and SW
2 5/8 gauge.
Thanks
Perry
Old 12-03-2002, 12:29 PM
427 S/O's Avatar
anyone have/had this problem?.
Perry
Old 12-03-2002, 12:42 PM
Homewrecker's Avatar
Mine is stable. You can see it move very, very little when you shake the car, but it's not a problem when driving. I have the same setup as you. Does your guage read correctly when the tank is full & empty? I know there are a couple different ohm senders for different guages. If your reading is off it may be the wrong sending unit (too sensitive). If not I would agree with the baffling problem in the tank.
Dave Brouwer - I'm going racing!
Old 12-03-2002, 12:44 PM
Shade Tree Mechanic
Cobra Make, Engine: - Unique - 302 - 4 spd. -
Perry,
Everything is working just fine..... this is a common "problem" using these gauges. There is absolutely no dampning in the gauge and the thing responds very quickly as the float in the tank moves up and down as the gas sloshes around in the tank. Only time mine reads without jumping around is when the tank is really full!!!
- Jim -
- Jim Harding -
- Capital Area Cobra Club -
- Just another day in Cobra Paradise -
Old 12-03-2002, 12:55 PM
427 S/O's Avatar
Same here but, I'll bet somethings out there that will slow down the signal,
perhaps a heat sink or whatever.
Hopefully someone will have found the answer?..
Thanks
Perry
Old 12-03-2002, 01:09 PM
Try doing a search for anti slosh on Yahoo. It may give you what you are looking for. Don't know if it can be adapted to your car, but it exists. There is also a topic about this going on at another Cobra forum.
Old 12-03-2002, 02:06 PM
427 S/O's Avatar
Did the search and found a fella building a cobra, he used the anti slosh module
out of an 88 stang, I'll see if it works with SW.
Perry
Old 12-03-2002, 02:09 PM
427 S/O's Avatar
Homewrecker, I emailed SW asking about this problem, Their still dragging their a$$.
Perry
HTML code is On
