SUPPORT OUR SPONSOR
Old 01-27-2003, 06:44 AM
Jay Jay is offline
Default SW spedo to C-6 trans
I was wondering if anyone knows how to adapt a SW electrical spedo sending unit to a C-6 trans. I contacted SW and they were not much help. There is an adapter from SW, but I am not sure if that will do the trick.
Thanks,
Jay
Old 01-27-2003, 03:56 PM
Mr.Fixit's Avatar
Doesn't the C-6 use the same speedo cable as a toploader? If it does, then it is a direct bolt-in part. Replaces the speedo cable with an electric sender and it's cable. I only put one electric speedo in a cobra, it went into tremec. The tremec needed a tiny bit of work with a die grinder to give the adapter room to sit in place. best guess
HTML code is On
