SUPPORT OUR SPONSOR
Old 02-11-2003, 10:22 AM
wicked fast's Avatar
The longest build.....
Cobra Make, Engine: Mid-States, 428 Police Interceptor, TKO 5 speed, Jaguar rearend, Trigos, and Guardsman Blue!!!
Question Sealing rough fiberglass ???
I am getting ready to start working on the interior.
Really, really hate getting poked with the loose shreds of fiberglass.
I am thinking about smoothing out the rough glass
with 40 grit, and then sealing it with brush on
Rustolem paint.
Has anyone done anything like this,
think it will stick very well ??
Thanks,
Bill Cook
If you were to die tonight, are you 100% sure
that you would go to Heaven ??
www.bluecarministries.com
Old 02-11-2003, 10:44 AM
Back in Black's Avatar
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Lightbulb My hardtop
Has exposed fiberglass on the inside.. it is not rough, but I don't like the look, or the tiny particles of fiberglass that potentially can fly around in there as a result.. so I am using the latest 3M undercoating product.. it is in a spray can, dries hard, pretty thin, and with a reasonably smooth finish.. perfect. I bought it at a professional paint supply shop here in town.
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
Old 02-11-2003, 10:57 AM
Mr.Fixit's Avatar
Why don't you all just lay a coating of fiberglass resin as a gel coat?
Old 02-11-2003, 11:54 AM
G.R.'s Avatar
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Post
Having owned and worked on sailboats for 20 yrs I've encountered my share of rough fibreglas--resin works ok, but the best results I've gotten is by using the West Sytem for working with and finishing 'glass--
You can find info on their website or at most marine suppliers or even body shops that specialize in fibreglas repair.
Have never tried BnB's idea, curious as to how well it holds up.
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
Old 02-14-2003, 08:58 AM
I too used the 3m product on the inside of my trunk and the fenderwells. It looks great and didn't get little hairline cracks in it like some of the cheaper brands available at the local auto store. I actually bought 3 different brands and sprayed test panels. The 3M was the clear winner.
p.s. I'm always running tests like that. Let me know if you want the clear winner for corrosion control of exposed or non-exposed steel.
Old 02-14-2003, 09:24 AM
CobraDan's Avatar
I'm working on a hardtop for my Cobra and I didn't like the raw fiberglass look on the inside so I used Bondo body filler, and sanded it to a smooth finish. If you use West Systems epoxy resin mixed with microlight fairing filler, it will also work but the drying time is a lot longer than Bondo. This also works well on finising off the inside of your hood, to show it off when its opened.
Dan
Display Modes
HTML code is On
