SUPPORT OUR SPONSOR
Old 02-11-2003, 02:28 PM
Question Quad Shock
I'M USING A 8.8 REAR END FROM A 1985 MUSTANG. DO I NEED TO USE THE QUAD SHOCK IF I'M USING COIL OVERS IN THE BACK. I HAVE HEARD THAT THEY ONLY STOP WHEEL HOP. BUT DOESN'T MY COIL OVERS DO THE SAME. THANKS
Old 02-11-2003, 09:14 PM
HighPlainsDrifter's Avatar
Cobra Make, Engine: F5 Roadster
Thumbs up
Hi,
The quad shocks are installed horizontally on a 5 OH mustang to stop the wheel hop created by large oval rubber bushings in the lower rear control arms. The best solution is to use aftermarket control arms with poly bushings and leave out the quad shocks.
Perry.
Old 02-12-2003, 05:50 PM
Cobra Make, Engine: SPF 974
The cure for wheel hop is in the pinion angle and rear end gemoetry. Set that and Instant Center correctly, your 8.8 will never hop and will hook much harder. This is achieved through proper angle of you upper and lower rear control arms and how they would intersect toward the front of your car if extended by an imaginary line. Your driveshaft angle between tranny & rear effects even power application.
Try a search on www.ffcobra.com where this subject has been discussed in detail under drag race forum. Folks say you can drop the quads if all is done right with coilovers or even properly aligned coil spring /shock set up. I kept mine ...it just made me feel better. A fatter tire would be nice though !
HTML code is On
