Old 03-09-2003, 02:23 PM
Default Jag pinion leak
Ive replaced the input seal w/ original leather seal .Still leaks Iv'e listened to stories of seals and venting to get it to stop leaking . I started to get local bearing supplier involved a couple of years ago and didn't fallow through.What do I need to do to get this stopped?
Mike H
Old 03-09-2003, 08:23 PM
KobraKarl's Avatar
Micheal C.,
Try "Jags +" in Everett they have been a big help solving e-type suspension problems.
Old 03-10-2003, 03:14 AM
427 S/O's Avatar
Michael, I replaced mine with the current rubber style, I'm surprised you even found a leather type?. I made an aluminum tool on my lathe that makes contact with the metal portion of the seal, it presses evenly as you screw down the pinion nut.
If you like, I will lend you the tool to use or you can make a copy.
Perry
Old 03-10-2003, 04:14 AM
Michael,
You do have a vent on the back cover, right?
Bob Putnam
-E.R.A.-
Old 03-11-2003, 12:16 PM
Shade Tree Mechanic
Cobra Make, Engine: - Unique - 302 - 4 spd. -
I don't have my info in front of me now, but you do know that Jag made two seals for the pinion? Different diameters, and do not remember if the difference was with the OD or ID around the yoke (maybe both?). Then again, maybe your pinion yoke is worn to point it won't seal correctly.
- Jim Harding -
- Capital Area Cobra Club -
- Just another day in Cobra Paradise -
Old 03-11-2003, 01:16 PM
chopper's Avatar
Cobra Make, Engine: Previous ERA owner on break
Cobra60426 is correct; there are two different size input seals for the Jag rear end, depending whether you have an "early" or "late" rear end. Also, the output seals are different between the two units. However (from just having pulled mine out and replaced all of the bearings and seals) the difference between the inside diameters of the two input seals should be readily apparent to the naked eye. The early unit input shaft has a smaller diameter than the later, so if you have a later unit, the early seal will not fit over the shaft. If you have an early unit, the late seal will fit over the shaft but it should be very obvious that it won't seal.
I'm not familiar with the leather seal. I replaced mine with Federal-Mogul seals. The Haynes manual which I have says to be sure to lubricate the seals with petroleum jelly rather than grease. Apparently they feel that the petroleum jelly will dissolve more readily in the differential fluid and allow the differential fluid to more completely lubricate the seal. I actually used some Parker's O-ring lube when I reassembled mine.
One unusual characteristic which I noted when I disassembled my unit was that the input and output seals were seated completely in the housing, rather than being seated until just flush with the outside of the housing as is usual with domestic vehicle applications. This allowed some corrosion to form on the unprotected surface of the shafts which were outboard of the seal. I had to have one of the output shafts sleeved to restore the sealing surface. If you have the unit out, you may wish to check and ensure that the sealing surface on the input shaft is smooth and will mate properly with the seal. It only takes a small amount of irregularity to wear the seal out in short order. If so, a competent machine shop should be able to procure and press-fit a thin sleeve over the original shaft which will restore the sealing surface. Hope this helps. Having just gone through this, you have my sympathy.
BTW, my undying gratitude to Doug at ERA for his patience in dealing with my one billion and two phone calls to ask for more free advice during this odyssey.
Some folks drink from the fountain of knowledge; others just gargle.
Yesterday's flower children are today's blooming idiots.
