Old 03-12-2003, 03:44 AM
GeorgiaSnake's Avatar
Cobra Make, Engine: Sold - Unique FIA - SA 396 Stroker
Default Where To Mount MSD
I'm laying out the harness and trying to find the best spot for the MSD Box. Comments and pictures would be great.
Randy
Sold the Unique - Bought a Porsche TT - Sold the TT - Bought a truck
Old 03-12-2003, 04:22 AM
keep it away from the heat and where water wont run on it. mine is mounted on passenger side footwell area, up under dash where it is protected from engine bay heat, feet and water. they don't like to get hot as that is when 'msd' means 'mighty sorry device'. bill.
Old 03-12-2003, 04:26 AM
Hotfingrs's Avatar
mines mounted in the same spot.....
Jack
XSSIVE .....
Old 03-12-2003, 04:36 AM
427 S/O's Avatar
My MSD and coil is on the firewall, inside behind dash and insulated, ordered an extra 4' wire from MSD. I was a littled
concerned about the distance from the distributor but after many miles, no problem.....
Perry
Old 03-12-2003, 05:22 AM
DougD's Avatar
Ditto - mine's on the firewall, passenger side, inside the passenger compartment. I figured it would stay cooler and dry there, plus it's out of sight. If you get the 6AL, remember to mount the box so you can get at the rpm limiter chip, should you want to change it.
Doug
Old 03-12-2003, 06:11 AM
jhaynie's Avatar
Mines on the passenger side firewall behind the dash also. Must be the place to mount it.
John H
Old 03-12-2003, 07:15 AM
Cobra Make, Engine: CSX4285, Shelby aluminum block 427, 40th Anniversary Model # 5
Default MSD Box
I've got mine on the passenger side footbox--inside the box on the top--out of sight--dry--and easy to get too.......
Old 03-12-2003, 07:21 AM
chopper's Avatar
Cobra Make, Engine: Previous ERA owner on break
I've got mine mounted on the back side of the dashboard, on the passenger side. I have two small pieces of angle-iron, attached to the dashsboard and dampened by rubber bushings, mounted vertically and bolted to the bottom dashboard brace. The MSD box is bolted to these uprights with the connections and limiter chip facing down.
Some folks drink from the fountain of knowledge; others just gargle.
Yesterday's flower children are today's blooming idiots.
Old 03-12-2003, 11:03 AM
What a great site
Thanks guys - looks like it's in the upper part of the passenger footbox or backside of the dash.
Randy
Old 03-12-2003, 02:25 PM
427 S/O's Avatar
I use the same S/S bolts for the MSD and the crankcase oil breather.
Perry
Old 03-13-2003, 11:43 AM
Roscoe's Avatar
Roscoe
Old 03-17-2003, 06:53 AM
Naja's Avatar
Hey, here's a radical location for you - in the trunk! It's a 7AL-2, but that's where the guy who set up my EFI puts all of his units. No problems due to the long wire runs, either.
Viva la differance!
Old 03-17-2003, 07:02 AM
Pete C's Avatar
Cobra Make, Engine: ERA 427 SC #004 (Original ERA?)
Roscoe,
The engine bay is not a good spot. I had my first MSD mounted there and I cooked it….too much heat. My engine seemed like it was running too fat and after screwing around with carbs I finally realized that there was an ignition problem. I now have mine mounted against the firewall in the passenger footbox. It is much cooler there.
Cheers, Pete
Drive it like you stole it!
Old 03-17-2003, 11:42 AM
Roscoe's Avatar
Pete,
I hear ya. I've had this mounted there for almost 3 yrs and 13k. So far so good. Too late to move it now.
Roscoe
Roscoe
Old 03-17-2003, 04:39 PM
roscoe, you be a lucky dude. they don't like heat, that is when msd=might sorry device. bill
