SUPPORT OUR SPONSOR
Old 03-22-2003, 02:39 PM
Default Contemporary front brake help
I have the coil over set up with pin drives. I have Wilwood superlite four pot calipers and wonder if anyone has a six pot set up. Also one of my discs looks to have a hairline stress crack in it and I would like to replace it. Does anyone know where I can get new replacement discs. The ones I have are 11 inch vented I think they are Brembo. Are cross drilled ones available? If you have a coil over set up with a different brake system that you feel really works well I would appreciate the details.
Old 03-30-2003, 06:59 AM
Cobra Make, Engine: Contemporary, 427 EFI; CAV GT40, 427W
If they are stock discs they should be for a Jag XJ series ~11." I may still have a set of unused rotors arround. I ended up developing a 14" brembo rotor setup before I finished the car. Pictures of my new setup should still be on this board.
Gary
Thanks
Gary
CAV GT40 Dealer
www.2gmotorsports.com
Old 03-30-2003, 08:52 AM
KobraKarl's Avatar
Gary ,
Nice work on the fronts ,I'm still with the series 1, could you provide a couple details of what you did? and does that setup fit behind 15" wheels?
thanks Karl
Foolish consistancy is the hobgoblin of tiny minds
Old 03-30-2003, 10:41 AM
Details:
- selected light weight Brembo 14" rotor
- designed custom aluminium top hat that would locate the rotor in the best spot and fit the XJ bolt pattern, etc.
- design and build a custom Cr Moly Steel bracket to locate the caliper in the correct spot relative to the rotor.
- upgraded to all aircraft quality hardware to hold on rotor and for caliper and bracket.
Will only work on 17" and larger wheels (may for 16" but I doubt it).
Thanks
Gary
CAV GT40 Dealer
Old 03-31-2003, 06:28 PM
SCOBRAC's Avatar
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
Yet another reason to turn your Trigo's into a coffee table.
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
HTML code is On
