04-01-2003, 08:52 PM
The "Gap"
,,the gap does indeed look a little wide,,,,,hard to tell. Wonder what is recommended for this application and what you got?
Ernie
EDIT: With "after market" electronic ignition sustem where the voltage is SUBSTANTIALLY higher than the "original" point type ignition you COULD run a larger gap, and it WILL be better than "stock". Stock was about 15 to 20,000 volts. Electronic will be 40 to 100,000 volts, much bigger "spark" and wider "gap" make for good things.
