SUPPORT OUR SPONSOR
Old 04-24-2003, 05:14 AM
Default jag rear/toploader fluid levels
I am close to putting new buld on the road...how much and how do you determine fluid levels for gear oil in Jag independent rear and tranny fluid for 4 speed toploader...both are currently dry...THANKS
Old 04-24-2003, 06:03 AM
wilf leek's Avatar
Cobra Make, Engine: Crendon, windsor 408 stroker, tremec. Also GSX008
Jag rear - there should be two plugs in the diff, one on the bottom, (for draining) and one in the rear cover. Fill until it dribbles out of the rear cover plughole. Level the car for this.
Toploader - don't know!!!
Wilf
Old 04-24-2003, 06:21 AM
Tom Wells's Avatar
Hi jdeuel87,
What Wilf said, plus for the Jag rear if it's posi you'll need a couple of bottles of GM posi fluid in addition to the gear lube.
Tom
Old 04-24-2003, 06:46 AM
427 S/O's Avatar
Fill'em both till it runs out and your done.
As for the friction modifier, I've heard don't and do?. The supplier for my jag rear parts said don't, so I didn't, figured he knows best.
Perry
Old 04-24-2003, 06:54 AM
Cobra Make, Engine: Unique 289FIA / SA 351W / a truly glorious machine
Wilf,
What are the particulars concerning the Jag rear-end and suspension? What are the key points to look for regarding lubrication and frequency of checking?
Any info from anyone would be appreciated....
al
Old 04-24-2003, 07:19 AM
wilf leek's Avatar
Al - I grease all the wishbone pivot bearings twice a year, ditto halfshaft UJs. Top up grease in wheel bearings once a year.
My car sees about 4000 miles a year, so I guess this is overkill, but so is everything else I do on my cobra. The way I drive it, it is cheap insurance.
Rear end oil I change every year, ditto gearbox.
One good thing to rememember when building up a jag rear end is to use the correct (angled) grease nipples on the outboard UJs - and angle them towards the car centreline - you can't get on the straight ones once they are buried in the hub carriers.
Once a year or more I check for play in all the elements of the rear end - wishbone pivots, UJs, hub/driveshaft splines - I found that it is almost impossible to get all the play out of a jag rear end, but now that I have a baseline.....
hth
Wilf
Old 04-24-2003, 08:10 AM
Tom Wells's Avatar
Hi again jdeuel87,
You may wish to check out this thread regarding the friction modifier for the Jag limited slip (if you have one ):
CC limited slip friction modifier thread
Tom
HTML code is On
