SUPPORT OUR SPONSOR
Old 04-30-2003, 11:18 AM
Default Tach hook up MSD with Smith Tach
Hey everyone,
I have a Kirkham that has a MSD ignition. How do you hook up the Smith tach?
Thanks, Tom Lucas
Tom Lucas, FE Specialties Sacramento, Calif. 916-339-0427. Our Engines are designed and engineered, not just thrown together. I design engines for every application. From mild street engines for torque to mid type performance engines for Cobras and Mustangs too fullout Race engines for Nascar and NHRA.
Old 04-30-2003, 12:02 PM
Bud Man's Avatar
Cobra Make, Engine: Former Owner/Builder of KMP142 427 Sideoiler, Tunnel Wedge, Aluminum heads, etc.
Tom:
There is an MSD adaptor that is usually furnished with the tach, and you need it to do the install. It is a small unit that mounts under your dash. Your tach has three male spade connections, input, output and ground....the adaptor has four - input, output, ignition and ground The MSD module has a recessed spade connector on its side that runs a single wire to the adaptor.
Installation is very straightforward, and if you have purchased the Smiths MSD adaptor, the instructions that come with it are very clear.
Bud
Old 04-30-2003, 12:51 PM
Mr.Fixit's Avatar
It depends, there are two different styles of Smiths tachs I have seen in cobras. One needs the MSD tach adapter, as well as a large discoidal capacitor inline with the tach signal wire. The other type works fine just connecting the tach output lead from the 6AL directly to the tach. Try hooking it up from the tach output on the 6AL directly tothe tach, just you would with any tach. If that doesn't work, get the capacitor free from MSD. If those two don't do it, get the $30 tach adapter box from MSD. Or just call MSD's tech support and deal with them. The second type of Smith's tach referred to here has a single multi-wire connector, the first type has a couple of single wire connectors.
Old 04-30-2003, 01:15 PM
Hey Guys;
Thanks for the help!!!!
This Sunday, May 4th, at Sacramento Raceway, there is a Ford Swap meet, car show, and Drag race!! There will bew a lot of very fine Fords in attendance, so come out if you can!!! I will be running our 67 Mustang Coupe looking for 10.50s.
Tom Lucas
HTML code is On
