Old 05-17-2003, 05:37 PM
Todd Hedges's Avatar
Cobra Make, Engine: ERA 427SC w/428 & Richmond 5-speed Car 611.
Default What did I do ?
What's the deal with the Holley 4150HP?
Why is it so difficult to get replacement parts and pieces correct for this carb?
Difficult to find anyone local with metering block gaskets.
Is there a difference with the power valves on that carb, verse a "typical" Holley?
The power valves that were in the HP had only two small openings, and the power valves that I was given by the engine builder had four openings. Are they compatible, or will the 4 hole ones not work in the HP version.
...."they say I'm crazy, but it takes all of my time."
Old 05-18-2003, 09:12 PM
KobraKarl's Avatar
Todd
Dont worry about the holes ,they vary from one manufacturer to another , just make sure you get the right number and gasket for your particular PV.
KK
Old 05-19-2003, 02:37 PM
Mr.Fixit's Avatar
A 4150 is a 4150. Just make sure your new gaskets look like the ones you took out.
Old 05-21-2003, 08:28 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
PAW, JEGs
Call them and tell them the gasket you need.
Trularin
