SUPPORT OUR SPONSOR
February 2026
Old 05-28-2003, 04:27 AM
347's Avatar
347 347 is offline
Cobra Make, Engine: .
Default ram tubes
tonight i changed my idle jets to 55's and i left the ram tubes off with no air cleaners and it fixed my flat spot between 1500-2500 and the surging while cruising around the same rpm)
how does that change the performance of the engine?
when i was driving it seemed to hesitate a little(nothing like the flat spot with my old 50 idles,bloody hard to explain :cry: ) on medium to hard throttle when in 2nd or third gear???????
am i loosing it or what????????
Old 06-29-2003, 03:27 AM
Cobra Make, Engine: Berry Cobra ,Tremec 5 spd . 408 windsor , double A arm 9"rear
I have a old book with weber carb settings for dcoe & IDA there is listings to get you in the ball park I don't know if the parts are similar ? . chev 4949 cc full race 4x48 DCOE ,choke 40 , main 165 , air 160, emulsion F2 , pump 50 , Pump bleed closed , idle 55 F8 , Auxilliary venturi 4.5 , sorry its a chev, the ford has got IDAs .
HTML code is On
